​ Welcome Forum Guest! 👋 ​
How to know if a digital odometer has been tampered or adjusted?
1 hour ago, kadsa98 said:
Not easy to do on the car because it takes a while and you have to mess around with the ECU. I've only seen this done on a 2014 iish Audi A8 when I was back in SL but it is possible to do on any newer euro. I don't condone this stuff though!
I am not sure how this has done in SL and what equipment they used.
I had to replace the cluster on my 2006 TDI Jetta took only less than 5 min to get the ODO to the correct value, done via the OBD port.
one of the Toyota digital cluster wasn't that straight, I have to take the cluster out for them and they solder 3 wires into a box which then connected to the laptop via com port, took them about 20 - 30 min.
What I have heard from the auto repair shop any euro digital meter post 2000 takes less than 5 min to change.
regards,
JC
regards,
JC
There was a fifth-gear episode on this....they got a car thief to actually change the mileage on camera....took like 5 - 10 mins....
