Hi Guys,
Does anyone here knows whether we can change the language of Audio Setup in honda fit gp1. It's Gathers VXM 128VS. I'm curious has anyone done it before or if it's possible. I my self tried this using the Manual and couldn't succeed. There were couple of YouTube videos as well which we can use google translator to find out correct language settings that didn't work as well. If you guys have any experience or knows a place a do so I would be really great full.
2 hours ago, Corolla141 said:
Hi Guys,
I used a 2012 GP1 from 2015-2018 : came with the same unit Gathers VXM 128Vs : save yourself the trouble you cannot change the language. I just used the google translate app on my phone and in time got used to the button layout. The only other option is to install a new unit but since I was perfectly ok with the original unit i didn't do so.
Thanks buddy. I guess I will be sticking to it. Btw dp you have any idea on the impacts if I change the Audio Setup. When i went through the set up I saw there are some indicators like filter change. Is this more than a typical audo setup where you can just replace.
It's doable on my VXM 128C (no bluetooth). So must be doable on yours too. Took me a while to get it right with Google Translate app. But the change takes away half of its features.
  • 1 year later...
I have managed to change the language. Thank you. However now it does not show the rest of the menu's shown when it was in Japanese language. Also home button is gray. Any idea how it can be get active. Many thanks in advance.
  • 1 year later...
