vitz Posted September 1, 2020 Share Posted September 1, 2020 Hi All, Many of us including myself do the routing maintenance work including oil/filer change to save time wasted at service stations as well as the do the work properly. Though, we focus mainly on oilchange/oil filter change/airfilter change/cabinfilter change like key maintenance aspects, I thought it would be better to create a check list of activities thus the work done properly. First we can list the set of activities then our experts can quote each activity and add more details,,,,,,, 1. Check drive belt for cracks, fraying, wear, and adjust its tension 2.Check intake air hose for damage (vehicles with turbocharger) 3. Check radiator hoses for damage and proper connection 4. Check engine coolant level in reservoir 5. Check air cleaner element for clogging and damage 6. Replace air cleaner element 7. Check fluid level in brake reservoir and clutch reservoir 8. Change brake fluid - better done at the agent 9. Check battery condition 10. Check suspension system for damage and looseness 11. Replace fuel filter - through agent 12. Check suspension arm ball joints for play, and dust covers for damage 13. Check driveshaft boots for damage 14. Check steering linkage for damage and loose connections (including seals and boots) 15. Check manual transmission for oil leakage 16. Check transfer for oil leakage 17. Check exhaust pipe connections for gas leakage, and check pipe installation 18. Check brake pedal and clutch pedal for free play 19. Check brake pads and discs for wear 20. Check fuel hoses and pipes for leakage or deterioration 21. . 1 Quote Link to comment Share on other sites More sharing options...
Splat Posted September 9, 2020 Share Posted September 9, 2020 that's a good list Thank you for posting. Quote Link to comment Share on other sites More sharing options...
