why is not working honda fit gp 1 welcome lights
1 answer to this question
22 hours ago, thamindu nethusara said:
one welcome light is working others are not working <driver side is working>
these are aftermarket installs so you can start by checking if the +12V from the battery is working (the power line to the controller), then check the ground connection of the welcome lights to the door switch. Finally if both these are fine then it could be a burnt out LED in which you need to buy a new light set for it.
