Hi Guys,
i have a Hyundai 2003 Model Accent. it has done 25,000KM. The engine oil i have been using is
Caltex 20W50....
i wanna know if i change to Mobil 1 10W40 will it improve anything ???
Hi there
What is the manufacturer recommended oil rating? Determine this first.
The rating of the oil you put in your engine plays a key role in how a lot of the internal components of the engine performs their duties. Especially when the engine is still relatively new. So sticking to manufacturer specs is quite important.
Since your car is still pretty new (25,000km) stay with the manufacturer's suggestion.
Caltex or Mobile? This does not matter all that much as long as you are using a well known brand. However, do not mix different brands. Even when using the same brand of oil stick to the product you have been using. Also don't mix synthetic with non synthetic.
Your car seems to average around 8,500km per year. The recommended service interval might be over this milage. But do not wait for the said milage to reach. As a norm I go by "manufacturer suggested milage for oil service or six months. Which ever comes first".
Also keep away from recycled engine oils. Some may argue with me on on the grounds that recycling technology has vastly improved over the years. But I am yet to be convinced.
Cheers
Mods we need to close & merge this thread with the older/existing one on engine oils :unsure:
thanks guys....
what abt the grade
5w40, 10w30, 15w40, 20w50 which one should i go for
