    Β
ya think?? naaah... I don't like that. Too twitchy. I don't have the confidence it will stay within it's control envelope when I ask to to do strange things. The backside loses it waay to easy. Unlike the VZR, which responds like its on rails.
Actually, I have the budget to accomodate it. Not interested.
How much is he paying u too to advertise the honda on the forums like this?
hei bro did u check the back tyres. probably worn out. put some new tyres that grip
hehehehe
:blink::blink::lol::lol:
anyway congrats for ur new car, what Z u have ? im too confused are they R/C cars :lol:
post some pics buddy
hehehehe
:lol::lol::lol::lol:
anyway congrats for ur new car, what Z u have ? im too confused are they R/C cars :P
Nah, it aint the tires. vshiznet says its to do with haveing stock EXi springs. Whatever. It slides, as is, right now.
Actually, two R/Cs (a 1/10 and a 1/28th) and one model (a 1/18, that was a birthday present from madmax :D ) There are pics on both my sites.
what sort of strange things do you ask it to do... :blink::blink:
wat on earth do u do wit its backside? pericles! tsk tsk :P
Oh, shush, u two. y'all know what I mean.
  • 4 weeks later...
Hey pericles from where do u get the RCs are they Nitro powered,How much will one Modified nitro Rc be n where can i get one . (IF U CANT POST THEM HERE pls mail me the info @ [email protected]
Co-incidentally, a friend of mine is trying to sell his nitro powered Impreza :D Interested?
I have 3 Z's that are too small for me ;):lol:
Probably too much... :D 1.7 was the agreed on in the end. I'll keep u in mind when I want to sell it tho. Which would probably be later this year.
The VZR is pretty nice, its had a N1 engine change, right? My brother checked both the VZR and the SiR out. The SiR had too many dodgy mods done to it.
Hey Pericles, whats the 0-60 of the VZR like?
I have no idea. Yet to do a timed run. I'll let u know when I get it done.
Co-incidentally, a friend of mine is trying to sell his nitro powered Impreza :action-smiley-060: Interested?
pls use the classifieds to sell your items!! :blink:
better use a calender to do the timing...
Don't think there is a category for R/C in the classifieds.... but all right, lets see what we can do.
can some one post some tech details of the vzr
:blink:
SR16VE
The 1.6 L SR16VE has Nissan's Neo VVL variable valve timing with lift control. It produces 170 hp (127 kW) and 119 ft.lbf (161 Nm).
It is used in the following vehicles:
* N15 Nissan Pulsar VZ-R
SR16VE N1
This version was used in the limited production Nissan Pulsar VZ-R N1 and Pulsar VZ-R N1 SSS from 97-98 and made 197hp @ 7800rpm and 134lb torque @ 7600rpm from the 1.6L SR. Although this car was limited in production(only 500 or so models are rumored to have been made).
Source : Wiki
This thing is copied in so many forums, might as well put it here too :action-smiley-060:
The VE (Neo VVL) series of engines is Nissan's answer to Honda's VTEC. The two systems are nearly identical. They use the same concept of multiple cam lobes to provide a low rpm cam ideal for torque and a high rpm cam optimized for hp. The only difference in the Nissan system is that the intake and exhaust cams are triggered indepedently for a flatter, more consistent power band. You can read more about the VTEC system here (http://www.leecao.com/honda/vtec/whatsvtec.html).
How many different VE motors are there?
There are five (5) VE motors.
SR16VE - 173hp 5 speed Manual 97-2001
SR16VE N1 - 197hp 5 speed Manual 97-98
SR20VE - 187hp CVT 6 speed Auto 97-2001
SR20VE - 204hp 6 speed Manual 2001-Present
SR20VET - 276hp AWD Turbo 2002-Present
How much power does the VE have?
SR16VE - 173hp @ 7800rpm / 119lb torque @ 7200rpm
SR16VE N1 - 197hp @ 7800rpm / 134lb torque @ 7600rpm
SR20VE - 187hp @ 7000rpm / 145lb torque @ 6000rpm
SR20VET - 276hp @ 6400rpm / 228lb torque @ 3200rpm
How much do they cost?
SR16VE - $1000-$1600
SR16VE N1 - $3000+ good luck finding one*
SR20VE - $1000-$2500
SR20VET - unknown
*Only 500 of these engines are thought to have been produced.
**These are average prices based on availability and engine condition. Actual prices may vary.
What are the origins of these motors?
SR16VE - 1.6L VVL motor found in the Nissan Sunny Lucino VZ-R, Sunny GT and Pulsar VZ-R.
SR16VE N1 - 1.6L VVL motor found in the Nissan Pulsar VZ-R N1 and Pulsar VZ-R N1 SSS.
SR20VE - 2.0L VVL motor found in the Nissan Primera (Infiniti G20 bodystyle), Bluebird, Wingroad, and Autobacs Garaiya.
SR20VET - 2.0L turbocharged VVL motor found in the Nissan X-Trail SUV, and Trailrunner Concept Car.
Source : sr20forum
On the Car itself
1998 Nissan Pulsar VZ-R N1
Bodywork
Type: 4/5S HBK
Number of doors: 3
Dimensions
Wheelbase: 2535 mm 99.80 in
Track front: 1470 mm 57.87 in
Track rear: 1435 mm 56.49 in
Length: 4140 mm 162.99 in
Width: 1690 mm 66.53 in
Ground clearance: 135 mm 5.31 in
Kerb weight: 1090 kg 2403.03 lb
Fuel capacity: 50 l 13.20 US gal
Engine
Manufacturer: Nissan
Type: S-4
DOHC
16 valves total
4 valves per cylinder
Bore x stroke: 86.00mm Γ— 68.70mm
Bore / stroke ratio: 1.25
Displacement: 1596 cc 97.39 cu in
Compression: 11.60:1
Fuel system: EFi
Aspiration: Normal
Catalytic Converter: Y
Max. output: 199.7 PS (197.0 bhp) (146.9 kW)@7800 rpm
Max. torque: 181.0 Nm (133 lbft) (18.5 kgm)@7600 rpm
Coolant: Water
Specific output: 123.4 bhp/litre
Specific torque: 113.41 Nm/litre
Performance
0-100km/h: 6.8 s
Quarter mile: 14.89s
Power to weight: 180.73 bhp/ton
Engine location: Front
Engine alignment: Transverse
Steering: rack & pinion
Turning circle: 10.40 m
Suspension front: I.MS.
Suspension rear: I.MultiLi.
Tyres front: 195/55 VR 15
Tyres rear: 195/55 VR 15
Brakes: VeDi/Di
Transmission: 5M
Drive: FWD
Top gear ratio: 0.76
Final drive ratio: 4.44
Source : Global Car Locator
i expected it to be heavier...180bhp per tonne?damn i only get 120 per tonne lol
thanks for the detail tho dude
That is without the driver :( To be specific, without THIS driver. Madmax won't alter the figures too much.
What do u mean dodgy mods that was one of the quickest 4 door honda civic. And i'm sure it still is the second fastest 4 door civic :(:blink: we should run the two cars to decide on the title Madmax :lol: Any 4 door civics who want to participate to find the fastest honda civic sedan in SL.
What do u mean dodgy mods that was one of the quickest 4 door honda civic. And i'm sure it still is the second fastest 4 door civic :D :D we should run the two cars to decide on the title Madmax :D Any 4 door civics who want to participate to find the fastest honda civic sedan in SL.
Hey hey hey. No civic arguements on my car thread.
U guys realise, that with that SR20VET running 276hp, if Nissan bothered to develop an all-wheel drive sedan, it wold have summin to compete in the Evo/WRX class? Imagine a Pulsar Evolution :lol: They already tried a 2L turbocharged rally car in the GTiR. They have the 4 wheel system thats second to none. Early versions of ATESSA were tested out in the GTiR. Just a matter of if they have the suspension to put into a car like that....
Sweet idea, eh? :(:blink:
Just remembered. My car has an aftermarket soundsystem that weighs more than vshiznet.
it'd be ugly...the primera p11 is more the car for it :lol:
Yeah, that Camino model. Damn, why didn't they think of this? guess they were going thru too hard a financial situ to put much money into R&D for racing.
And don't call my car ugly. :(
Hey pericles, is VZR produces the highest BHP from a NA engine out of all 1600cc japanese cars??
someone told me its honda. :blink:
That I'm not entirely sure. I think there is a civic mark that pushed 200 or close to it too. Type-R? not sure. U'll need to check that out a bit on the web.
What do u mean dodgy mods that was one of the quickest 4 door honda civic. And i'm sure it still is the second fastest 4 door civic :angry-smiley-048::D we should run the two cars to decide on the title Madmax :P Any 4 door civics who want to participate to find the fastest honda civic sedan in SL.
Ok, they weren't really dodgy mods, but there's a bit of concern when a 1.6 is squeezing out 190 odd bhp. I'm sure the life of the engine is fine if it has been serviced regularly.
And don't call my car ugly. :angry-smiley-048:
ur car is a minority...wen we talk nissan pulsar we mean the sedan unless otherwise specified :D
the type R b16b has 185bhp stock which is the most powerful 1600 honda...correct?
