Recommend a good mechanic for brake issues?
Hi guys,
I have a 2008 Swift and I am encountering some brake issues. The pedal is pretty hard to push, so am suspecting a brake booster issue? The car judders when at low speed when applying the brake. The pads are fine.
Can you recommend a good mechanic? I live in Madiwela.
There are plenty of garages around here, but in there are also too many inept mechanics around, and since this is an issue with the brakes I want to get it done properly and not get ripped off at the same time. I took my car once to a place in Kohuwala (near Laugfs), and they were somewhat expensive and also didn't do a complete job. When I returned and complained, the answers were vague and dismissive. I'm sure you all have been through this before. So I don't want to just walk into a some garage and get them checked out without some prior recommendation.
Thank you.
(Apologies if this question has been asked before, but I could find anything relevant in the search.)
Edited by Vlad
2 answers to this question
Worthwhile getting the braking system checked beyond the booster too.
Like if caliper pins are not sticking and pistons are moving freely as they should.
I get my work done at Bruce Motorsports. They are passing Malabe and you can locate on google.
Not a complicated fix so most shops should be able to sort it out.
Thank you.
