I'm having a Toyota Vitz 2007 SCP90 (2SZ-FE), as of recent when the tank on the car is full, the engine stalls at low RPM (at traffic lights, stop-go etc). But after stalling the car starts again without any issue. This happens often until some amount of petrol has been used from the full tank. Also the car does not accelerate as usual when this problem is occuring.
I recently did a tune up where all 4 plugs were replaced with new Iridium plugs along with 2 injector coils but this did not fix the problem as well.
The second time this issue occured, the petrol pump was replaced as the OBD scan codes showed that the issue was with the fuel, but the issue occured again. I went to Toy#ta L#nka to get a diagnosis and they concluded that the Airflow Sensor/Oxygen sensor 1 was failing.
Kindly note that there are no check engine lights while running, only time check engine light comes on is when the car stalls with a full tank during low RPM, that also goes away when the car is turned on again. The OBD code reading now shows up as rough idle.
I read an old AL thread which mentioned that replacing the MAF sensor fixed the issue for one of the members, but I'm not sure if it will help in my case as Toy#ta L#nka mentioned that the MAF sensor was good, only that the Oxygen sensor needed replacing.
I would like to get your opinion on this issue, as different sources point to many possible causes including EGR valve issues, MAF sensor failing, Oxygen sensor failing etc.
Since replacing the Oxygen sensor costs a significant amount of money, I would like to get a second opinion on what else needs to be checked to diagnose the problem before replacing the sensor.
Any place around the Malabe / Colombo area that would be able to diagnose the issue will also be highly appreciated.
Officially joined the thel-hinganna normie horde with ....drumroll... a 2025 Vezel... I am eagerly anticipating joining the 'thel keeyak karanawada' debates at almsgivings.
Recently, got the opportunity to see and get inside of The one and only Japanese V12, Toyota Century(a.k.a Japanese Rolls Royce). Is it really upto Rolls Royce standards? Nope, I don't think so. Items like Switches and mirror housings are in plastic. But, we can be assured that the dashboard will not light up like Christmas and would run forever....
RusT
Hi Everyone,
Cheers!
5 answers to this question
