Coolant Levels And Topping Up
i can't quite remeber but it was something around 1,400 odd i think... :unsure:
machang, coolent? just use caltex . cheap
Hi guysโ€ฆ here is what I found out.. (own experience)
  1. What ever the coolant you use itโ€™s always better to have a 1:1 ratio ( coolant : water) main reason being that the engine gets cooled by water & the coolant keeps the system from rusting.
  2. If you have a drop in your radiator water levels, itโ€™s not only may be due to a leak in the radiator it could be even the rubber pipes that are distributing the water to the engineโ€ฆthere could be a very tiny hole in one of the pipes where the water leaks.. the reason you might not see this is because the water evaporates when the engine is hot. When the car is cooled down ( over night) still you may not see because the water pressure & water heat is low.. so until the pressure & the heat builds up you will not see a leak.. itโ€™s very trickyโ€ฆ
I had a similar issue not easy to detect.
  • Author
Interesting find terabite. I guess hoses should be added to the checklist as well then.
While we are at it. What are the costs involved in replacing the set of hoses (is it just the 2 on the radiator or are there any more?)
Edited by Memphis
well that i am not sure.. i had a issue with two pipes.. not the main pipe, but two small ones.. cost me around Rs. 700.00 each... not bad..
I guess we can't mix any coolant with water. The way I have heard is that there are types of coolant that you can mix with water and others that you should not mix.
I use BP and they recommend, not to mix with water or even top up with water.
Edited by TurboSeavy
True it depends on the coolant being used. The BP cannot be mized as its pre mixed or factory mixed. Thats why it may cost a bit to use when doing a full fill up.
Hoses for Honda's are a bit more expensive. 1500-3500 bucks if I remember right varying by the size
thats a norm for hondas :(
i checked the reciepts - it read Rs. 1,450 for BP coolant to fill up the whole thing - abt 6 months back - & it is pre mixed as Pilla mentioned so don't bother with any water
this was done soon after the entire radiator was removed and serviced
Sorry dudes.. yes agreed that there are some type of coolants that don't need water... what i was trying to say was, you can use any coolant to your radiator i meant Caltex, ABRO etc....
as for the hose pipe prices.. it was 1700 each !!!!! not 700.. ( typing Mistake)
  • Author
Any cooling system diagnostic and repair places you guys recommend? I'm thinking in the lines of places which specializes in radiator/cooling system leak testing, servicing etc.
R*diator H*use is a sure bet if its only that - but dunno if they do the whole system
expereinces with them have been more with the core seperately as opposed to the whole vehicle being checked
located out in Maradana
Agents are the best for things like that.. I like the neatness in the way they depressure the system and remove the stuff
I think that must be for 2liters.. One was def. less than 800 bucks
Dev Z, did you ever change the water of the radiator?
yeah it was all taken care of that one time when i had pretty much the whole cooling system checked by the agents :)
