Lalithster Posted April 13, 2007 Share Posted April 13, 2007 Hey guys just got a clay bar kit from Mother's and am going to clay bar my M3. Has anyone done this before? ANything I should look out for? Thanks Quote Link to comment Share on other sites More sharing options...
hefraz Posted April 14, 2007 Share Posted April 14, 2007 (edited) Nothing much to look out for as clay bars are non abrasive, cut the clay bar and prepare it like a pancake which fits into your palm. Use a lot of lubrication (Since you have a kit I assume the lubrication is already there) and rub it all over the car. One word of warning, if you drop the clay bar on the floor- discard it and get another piece (claybars absord dirt very well) Surface preparation is important before you start claybarring. Make sure you wash the car and remove all tar spots, otherwise it becomes a bloody nuisance. And finally wax the car as soon as you claybar, otherwise you leave the cleaned paint open to the elements. Happy detailing! Edited April 14, 2007 by hefraz Quote Link to comment Share on other sites More sharing options...
miniace Posted April 14, 2007 Share Posted April 14, 2007 "Clay with a quick detailer cleans the top of the paint and by making the paint clean and slick you get more of a reflection .Reflection and shine basically is this"your paint needs some TLC,right now under microscope its like hills and valleys of build up and when the light hits it,it then has to bounce over these,there forth not a good reflection. Now buff or claybar or polish and you bring a level surface back for the light to reflect off of and there is basically where your shine and reflection to a degree comes from This is on todays clearcoats When you claybar you absolutley must have a dirt free surface and plenty of lubricant.You can use soap and water as a lube if needed" Quote Link to comment Share on other sites More sharing options...
Lalithster Posted April 18, 2007 Author Share Posted April 18, 2007 Thanks for the help. The clay bar is a must it makes the car so much smoother and the paint looks deeper and more reflective Quote Link to comment Share on other sites More sharing options...
miniace Posted April 18, 2007 Share Posted April 18, 2007 Great ! its good to hear that you are satisfied! Picture tells it all!! Quote Link to comment Share on other sites More sharing options...
ucscsades Posted April 18, 2007 Share Posted April 18, 2007 Lalithster said: Thanks for the help. The clay bar is a must it makes the car so much smoother and the paint looks deeper and more reflective damn, thats one cool picture! good job with the clay bar too! Quote Link to comment Share on other sites More sharing options...
Hola Posted April 19, 2007 Share Posted April 19, 2007 Lalithster said: Thanks for the help. The clay bar is a must it makes the car so much smoother and the paint looks deeper and more reflective hey your photos always looks good..8MGP i presume. Anyway good work, would you mind teling the brand and the way you applied it Quote Link to comment Share on other sites More sharing options...
ucscsades Posted April 19, 2007 Share Posted April 19, 2007 Hola said: hey your photos always looks good..8MGP i presume. Anyway good work, would you mind teling the brand and the way you applied it ..he already mentioned it's a Mother's? And I'm assuming you followed pretty much the directions you'd find on any clay bar kit/what other members advised you should do in above posts when the thread was initially made?! Quote Link to comment Share on other sites More sharing options...
Lalithster Posted April 19, 2007 Author Share Posted April 19, 2007 Thanks Hola its a regular sony camera and I set the setting for 1.5 mgp. The kit I used was mothers and it comes with a lubricant sprak that removes some of the dirt off the paint. I really recommend it. And its very important not to drop the clay bar or get it dirty cause that will scratch the paint. Also keep the surface well lubed when running the clay on it. It helps to ball up the clay bar after each section Quote Link to comment Share on other sites More sharing options...
MSP0RT5 Posted April 20, 2007 Share Posted April 20, 2007 (edited) Lalithster said: Thanks Hola its a regular sony camera and I set the setting for 1.5 mgp. The kit I used was mothers and it comes with a lubricant sprak that removes some of the dirt off the paint. I really recommend it. And its very important not to drop the clay bar or get it dirty cause that will scratch the paint. Also keep the surface well lubed when running the clay on it. It helps to ball up the clay bar after each section Actually I used to be a big AutoGlym & Meguirs fan, but last couple of years I've switched to mothers and been VERY impressed with their products! Even as basic as their car wash. any mother's resellers in SL? Edited April 20, 2007 by MSP0RT5 Quote Link to comment Share on other sites More sharing options...
Hola Posted April 20, 2007 Share Posted April 20, 2007 ucscsades said: ..he already mentioned it's a Mother's? And I'm assuming you followed pretty much the directions you'd find on any clay bar kit/what other members advised you should do in above posts when the thread was initially made?! Lalithster said: Thanks Hola its a regular sony camera and I set the setting for 1.5 mgp. The kit I used was mothers and it comes with a lubricant sprak that removes some of the dirt off the paint. I really recommend it. And its very important not to drop the clay bar or get it dirty cause that will scratch the paint. Also keep the surface well lubed when running the clay on it. It helps to ball up the clay bar after each section Sorry machang, i didnt get you earlier. Mothers is a brand right? Quote Link to comment Share on other sites More sharing options...
