Fb 14 Fuel Consumption
cdw
y did u go to Nissan FB14. y didn u think about toyota AE100 or AE110??? FB14 is not a good car. Anyway try to get tune your engine. talk to 0773667114 this guy called Srimantha. he will help u.
i have Fb 14 auto 1.5 EFI Car.
its running 5-6 Km per ltr city limits & 7-8 Km per ltr outstation
is it normal for that model ???
pls advice me !
Edited by Nilantha
yes 301 9xxx
Manual or Auto?
Have any of the following been checked recently:
Plugs
Injectors
Air filter
O2 sensor etc.
How is the condition of the exhaust? Is it full of thick black soot?
why not take it to a modern garage which has electronic diagnostics and ask them to run diagnostics on the system and see what's wrong with it?
Manual or Auto?
Plugs
Injectors
Air filter
O2 sensor etc.
i put genuine nissan plugs & air filter
clean injector 2 times ( 1st time machine then manual)
check the sensors
above all things done by modern garage & one time involve nissan (A*W) Technicians
but problem still exist !!
Nissans are not known for their fuel efficiency anyway...
have you changed the wheel sizes from stock?
Pi*st*p is a good place so i suppose all you tune ups are done fine...
How about engine compression...
do you get blue smoke...Sluggish startups...
If your loosing compression in the engine for whatever reasons it can affect badly on your fuel consumption...
Have you done any mods to your exhaust? beat barrels? fart cannons? etc
Are you using the right engine oil of the recommended weight... Heavier oils make the engine work a tad bit harder...
I don't know too much about auto transmissions but if your clutch is slipping that can also lead to bad fuel economy...
My 2 cents
cheers
R
check the sensors
5-6 city & 7-8 outta city is far too low, even for an AT. Do you have any modifications? Other than mechanical problems, your driving style could also result in a very low figure like this. U should get atleast 7-8 in CMB & more than 10 outstations.
my dad owns a FB14 which we bought ages ago it does 92 km on 1000 bucks of petrol with A/c in CMB and its an auto so i reckon urs is doing bit low on fuel i got size 14 wheels as well.outside we get a good 12 on the liter.its a good car runs really well dnt give much of a problem touchwood
