Nilantha Posted June 7, 2007 Posted June 7, 2007 Has anyone used ABRO or STP Engine oil treatment for your vehicle? Is it effective? Can we get some Engine Performance improvement using Oil Treatment? Quote
ThilakR Posted June 7, 2007 Posted June 7, 2007 Has anyone used ABRO or STP Engine oil treatment for your vehicle? Is it effective? Can we get some Engine Performance improvement using Oil Treatment? Hi, I use X-1R. It quite good. I experiencing some improvement in performance & fuel usage. Thilak Quote
Ripper Posted June 7, 2007 Posted June 7, 2007 Engine Oil Sludge Man these marketing guys are so good these days.. they can sell any crap with some sci-fi info pasted onto it :) Quote
Grand Civic Posted June 7, 2007 Posted June 7, 2007 I used X-1R . For me also it is quite good in performance wise & fuel consumpsion. Quote
Nilantha Posted June 7, 2007 Author Posted June 7, 2007 what is X-1R ??? price? where can i buy? can it mix with all engine oil? Quote
GTAm Posted June 7, 2007 Posted June 7, 2007 I doubt that there could be any difference if your engine is not wasted and you're using a very good synthetic oil. But some of these products do work. I used an oil treatment that increased the viscorcity of the oil on my very first car - a diesel mk2 VW Jetta. It sounded less like a tractor after the addition ! Quote
Nim Posted June 7, 2007 Posted June 7, 2007 what is X-1R ??? price? where can i buy? can it mix with all engine oil? can get it from quantum. priced around 1500. Quote
ThilakR Posted June 8, 2007 Posted June 8, 2007 what is X-1R ??? price? where can i buy? can it mix with all engine oil? Try any Arpico center. Thilak Quote
Ripper Posted June 8, 2007 Posted June 8, 2007 dude..don't use these crap in your car... good engine oil changed in decent intervals is all you need... these only help you to get more engine sludge... If you need more viscous oil due a to worn engine conditions try increasing the weight class of the oil you use... Quote
hawk_lk Posted June 12, 2007 Posted June 12, 2007 X1-R should be used only when you are having problem with your engine....like blue smoke etc........ Just do not pour into your engine without first getting some advice..... The above advice was given to me by one of the distributors of X1-R. So be careful....Like Ripper says regular oil change is good enough Quote
Tikiri Posted June 12, 2007 Posted June 12, 2007 Hi, I have used STP & Abro both in different cars, since 1995 or so on deisel's. what is your need, or what are you trying to achieve, they are good specially if your engine is around an overhaul, this would prolong your repair too, Quote
Archon Posted June 22, 2007 Posted June 22, 2007 Hey i too was interested in this subject and this X** oil...normally before making any move i go to google and do some survey on the product.. what i have found out is that most of these treatments tends to chemically breakdown in to harmful stuff by the time...eg: HCl (hydro chloric acid) so eventually your engine parts will be slowly dissolved!! so be careful. Quote
Nilantha Posted June 22, 2007 Author Posted June 22, 2007 Hey i too was interested in this subject and this X** oil...normally before making any move i go to google and do some survey on the product.. what i have found out is that most of these treatments tends to chemically breakdown in to harmful stuff by the time...eg: HCl (hydro chloric acid) so eventually your engine parts will be slowly dissolved!! so be careful. thank you 4 your comment. Quote
