I have a Toyota Corolla 2003 car. here, there is an issue in the headlamp. The issue is, that when I turn on the lamp, the low beam is working, but when I put the high beam, the lamp is not working. As well as the Pass mode of the lamp is working. The only thing is, that the high beam mode is not working. The head lamp's bubbles and Fuses are not broken. So can someone help me?
Most Probable cause is your Headlamp Stalk (Switch) is faulty. if the Relays and Fuses are fine then that should be your problem. you can check this yourself if your competent handling a Multimeter properly unless better seek professional help.
