Nissan Fb 13 1992 Model Ecu Unit
sira
Hi guys,
I have Nissan FB13(doctor sunny) which was made in 1992.recently i had a problem with the the ECU. if i reach 70kmph and applies brack and tried to change the gear in to 2,3 ( speed is 20kmph) the car gets knock and some times its stops un exceptically. i saw the ECU unit having the burned IC.so finally i replaced with same number of ECU unit.now the proble is solved. But i need to find out is there a way to check the ECU unit.
thanks
Sira
  sira said:
Hi guys,
thanks
Sira
ecu = zakie = 0777508864
zakie you better give me a commission bro :)
The way to check the ECU unit is to plug the car up to a an engine diagnostic system, and get a test report. You can get this done at any place or joint which offers such services and there are quite a few.
The report should indicate any problems with the sensors, the engine or the ECU
