Major Problems
1. Transmission- car won’t go forward until it has time to warm up.
2. engine mount - front engine mount needs to be checked/replaced.
3. Lower Arm bush needs to be replaced.
4. Right shock absorber need to be checked (possible leak)
Minor Problems
1. central locking not working on rear door.
2. a/c vent won’t stay up.
2 answers to this question
  • 1
Hi
Where are you from?
If around Colombo, Nilwala Motors in Madiwela is a good place for tranny related issues.
Also if you're going that way you can go to NSM Edirisinghe motors they have good selection of spares and a garage too for your other issues. Make sure to go early.
For the AC vents check Delkanda or the FB groups, 121 parts are not a rarity in SL😄.
For the door lock your locking module will have to be checked, a good electrician should be able to sort it out. Others will surely recommend / check older posts there were some good places.
Admins let me know if putting names of places goes against rules will edit it😄
On 8/11/2025 at 11:07 PM, RusT said:
Hi
Where are you from?
Hi Thanks for the recommendations. Got it fixed from Nilwala Motors.
