Hi guys... I,m new to this forum... Iv got a mini..Well i just wanna know wdr it'l be possible to fix this 2 inch RPM which is available at M_t_o_c_de.. A reliable plce to get this done?? Neat wiring too..
Thnx...
Any taco (RPM gauge) which counts the RPM through ignition pulse can be fitted to any Mini engine model. When fixing you will get the ignition pulse from the negative (-) terminal of your ignition coil.
Why make it look butt ugly by fitting a seperate RPM meter?
If u look around, u can get a 3-meter (Speedo. RPM and oil/fuel) meter unit made for minis. they are a tad bit expensive (about LKR 10000) but it looks good.
