ThunderBolt Posted February 28, 2008 Share Posted February 28, 2008 (edited) When I start my car in the morning I get a very strong petrol smell. I get it only in the mornings (cold start ) One of my engine coils is not doing so good and had some misses in the morning. Since it’s not worst I didn’t want to replace it. Because of that my rpm meter slightly fluctuate when idle state . (750 -800) can this be due to fuel filter I'm the second owner and has done 120 K. do i have to replace the fuel filter ? or clean it . I would like to know ur opinion on this situation. My car is a FORD Laser (Mazda BJ5P model) 2001 Edited February 28, 2008 by ThunderBolt Quote Link to comment Share on other sites More sharing options...
0 big Daddy Posted February 28, 2008 Share Posted February 28, 2008 Better get a tune up done. I had a FORD 2000 model and i used to have the RPM fluctuate problem. I got all the injectors clean and replaced Air Filters etc: Then the problem was not there again.. Better get the coil replced as well. Then you can iliminate it out from the problem... I don't think you have to replce the fuel filter... /bigDaddy Quote Link to comment Share on other sites More sharing options...
0 maithri Posted February 28, 2008 Share Posted February 28, 2008 If this has the Ford/Mazda engine I think they have a shared dry coil. These are prone to failure if the ignition system is overloaded-i.e. incorrect plugs, gaps even old age! Replace the coil ASAP along with plugs as well making sure the gap is right. These do suffer from fluctuating idle problems, mostly caused by contaminated throttle body, You may find a label asking you not to clean it, ignore and clean with a good quality air intake cleaner-I use W**th. Re fit and take it for a good drive to allow the ecu to re learn it's settings.DO NOT ADJUST THE THROTTLE STOP AS THIS WILL CAUSE MAJOR PROBLEMS> Maithri Quote Link to comment Share on other sites More sharing options...
0 ThunderBolt Posted February 29, 2008 Author Share Posted February 29, 2008 (edited) I got a tuneup done from the DPMC and they replaced my plugs to NGKs, I had genuine Mitsubishi plugs from my last tuneup. problem of switching speed when accelerating in second gear is still there (mis) my car is manual . Edited February 29, 2008 by ThunderBolt Quote Link to comment Share on other sites More sharing options...
0 Bugatti Posted February 29, 2008 Share Posted February 29, 2008 I had the same problem, mine is 2001 Mazda (manual) I got the injectors cleaned at D*MO and it worked. Quote Link to comment Share on other sites More sharing options...
0 ThunderBolt Posted February 29, 2008 Author Share Posted February 29, 2008 please tell me whe u got it fixed. any contact number Quote Link to comment Share on other sites More sharing options...
0 Bugatti Posted February 29, 2008 Share Posted February 29, 2008 ThunderBolt said: please tell me whe u got it fixed. any contact number Take it to D*MO, they've got a device that analyzes the spray patterns of the injectors and varied temperatures. You can call them on 449797, ask for the Bosch division and get an appointment. or drop me a mail to <colombo.2000@hotmail.com> Quote Link to comment Share on other sites More sharing options...
0 ThunderBolt Posted March 5, 2008 Author Share Posted March 5, 2008 Hi all I would like to thanks all for helping. Is there any drawbacks driving with his issue. coz i think replacing coils r bit expensive and DPMC told me to wait until it gets worst. this is the only issue i'm having @ the moment . Quote Link to comment Share on other sites More sharing options...
ThunderBolt
Edited by ThunderBoltLink to comment
7 answers to this question
