sltcdma Posted April 6, 2008 Posted April 6, 2008 Hi, I recently installed a budget car stereo. It works perfectly, but the problem is when the engine is running it gives continues "kreeeee" sound. I heard this is common problem with three wheels, this case with my car. I have connected power supplies to cigarettes lighter. Any one got solution to get clear sound. (except: engine turn off) Thanks Quote
Nisala Posted April 6, 2008 Posted April 6, 2008 I think this is due to the fan. It interferes some car stereos. But good quality sets not affcted Quote
Elvis_Pil Posted April 6, 2008 Posted April 6, 2008 A common problem with cheaper sets... some how the vehicles running current's frequency is picked up by the little built in amps... solution hmmm <bump> got me stumped- specially since your running in through the lighter outlet. Is that the only whay you can power it? Quote
sltcdma Posted April 7, 2008 Author Posted April 7, 2008 Hi Nisala, You mean that the fan behind the radiator? Hi Elvis_Pil, Lighter outlet preferred by the Technician Who installed the system. Do you think that if I connect it directly to the battery (or any other outlet), will the problem solve? Thanks Quote
Ripper Posted April 7, 2008 Posted April 7, 2008 Hi Nisala, You mean that the fan behind the radiator? Hi Elvis_Pil, Lighter outlet preferred by the Technician Who installed the system. Do you think that if I connect it directly to the battery (or any other outlet), will the problem solve? Thanks why not take the car to a good stereo joint and explain the problem and get something worked out... this might be due to fluctuations in the power supply or the head unit picking up electromagnetic signals from other electronic/electrical devices on the car Quote
chams_mini Posted April 7, 2008 Posted April 7, 2008 Hi guys jst want to get an solution for a similar problem.. The prob is when the car is not in start my stereo gives gud sound (with quality bass).. But as soon as i start the car the quality of bass sound decreases.. (My car is fitted with a beat silencer) Any idea why this happens? Solutions?? Quote
maithri Posted April 7, 2008 Posted April 7, 2008 Get a suppressor fitted to both the alternator and the ignition coil. Most cars need this to prevent radio interference, later cars seem to have these fitted by the factory. Maithri Quote
harshansenadhir Posted April 15, 2008 Posted April 15, 2008 Hi, I recently installed a budget car stereo. It works perfectly, but the problem is when the engine is running it gives continues "kreeeee" sound. I heard this is common problem with three wheels, this case with my car. I have connected power supplies to cigarettes lighter. Any one got solution to get clear sound. (except: engine turn off) Thanks have you properly grounded the setup.. or earthed in common terms? Quote
