Hi guys,
i require a hi-resolution image of the Sri Lanka flag. can someone guide me to 1 or email at [email protected]
its for my integra ... something that can be clear around A4 size print.
thanks in advance !!
emailed you a 35x17cm's @300dpi CMYK TIFF image that should be more than enough for your requirement and also a vector file that you can blow upto any size you want.
Not too sure whether it's 100% authentic flag graphic though cos minor details like the bo-leaves etc looks different from flag to flag for some odd reason.
Ripper mate any possibility of sending me the same? [email protected].
MINIACE
done deal ace...just sent it :) you would need Illustrator CS3 to open the ai file which is the vector one that can be blown upto any size. The TIFF should be A ok for upto A3 and more depending on usage.
majorly OT,
some news about the 5 29's we're getting from a guy who goes by the handle "Mig29-C" on LNP.... sounds bloody impressive :)
The MiG-29SMs on order will each be equipped with a Phazotron JSC-built Zhuk-ME (N-019ME) Multi-Mode Fire Control Radar, which has a proven 85km target detection range, and the capability to track 10 and fire at 4 simultaneously. It also has advanced air-to-surface modes that include Doppler-beam sharpening, synthetic aperture scanning (with 5-metre resolution) and moving target detection. It can track and target a truck sized target from 25km and motorboat at 120km. It can simultaneously engage 2 ground targets at once. It has a new mission computer in the MVK-04, which is substantially more powerful than the TS100 on the MiG-29A.
The aircrafts original IR Search and Track (IRST) sensor in front of the canopy, the 13S sensor on the MiG-29A is replaced with the Improved OPES-29 IRST unit. It has far greater range and far superior search limits in the azimuth and elevation. It is able to search, detect and track targets against their thermal radiation at all altitudes, in the lookup and lookdown modes, day and night and in the jamming environment as well as provide air or ground target ranging by means of a laser range-finder. In upgrading and integrating the optical electronic fire control & navigation systems, a new data display system is used in the MFD-54 multifunction colour display complex, with an additional weapons management control disply system in the centre console. Flight navigation and radio-communication is also added to the multifunctional computer, along with the GPS receiver and additional radio-stations. The aircraft also feature a new wide angle HUD.
Most importantly, the MiG-29SM avionics are linked though a MIL STD 1553B data bus.
The armaments suite will include Vympel R-73E air combat missiles, R-27ER1 and R-27ET1 medium-range air combat missiles, as well as KAB-500Kr laser-guided bombs that would be guided to their targets by manportable ground-based LDR-3 laser target designators supplied by Pakistan s Al technique Corp.
Also to be delivered in this time frame are 3 Oboronprom JSC-built Mi-35M attack helicopters.
The Mi-35M's for the SLAF will come fitted with a 9K113K all-weather weapons suite that includes an Urals Optical & Mechanical Plant-built OPS-24N 'Zarevo' optronic system, GOES-342 gyro-stabilised chin-mounted turret, IRTV-445MGII thermal imager with a 4km range, and the BREO-24 radio communications suite. The Mi-35M's cockpit displays are NVG-compatible.
The aircraft will have an all new main and X-shaped tail rotor fabricated from composite materials. While its main and tail rotor hubs and gearbox are the same as those developed for the Mi-28NE attack helicopter.
The original wings on the Mi-24 are replaced with new stronger, lighter weight stub wings on the Mi-35M, each equipped with twin APU-8/4U weapons pylons, each of which can carry four or eight supersonic anti-armour guided missiles (130mm 9K114 Shturm-S with 5km-range or 9M120 Ataka with 6km-range) depending on the weapons configuration.
The initial order does cover an unspecified number of 9K114M (HEAT) and 9K114F (Thermobaric) missiles.
While the SLAF will be responsible for first and second level maintenance of these new acquisitions, the Indian Air Force (IAF) and Indo-Russian Aviation Ltd (IRAL) will provide flying training, technical type-training and depot-level maintenance support for them. IRAL is currently providing similar product support to the SLAF's existing Mi-17V-5s, and Mi-24V/35P HIND Attack Helicopters, and for the 7 x Ex-Ukrainian MiG-27Ds and one MIG-23UB trainer of No5 Fighter Squadron.
This fact was a closely guarded secret until recently. However, it is only a matter of time before this is made public.
In addition to these acquisitions from Russia, the Sri Lankan Air Force is also upgrading several of its Kfir ground attack aircraft, along with a few Mi-24V's.
The SLAF recently acquired 2 - for the time being let me say - advanced UAV's from Israel. I will keep the make and its payload a secret till I deem it safe to say anything.
Anyway, along with this acquisition the Sri Lankan Government also brokered a deal with the Israeli Government for Elta to supply 4 x EL/M-2032 advanced Multimode Airborne Fire Control Radars to the SLAF. Crucially, the upgrade is to be carried out by Hindustan Aeronautics Ltd (HAL) - Sure to raise a few eyebrows is the fact that it is the Indian Government that is paying for these radars, not the Sri Lankan Goeverment.
The EL/M-2032 has greatly enhanced Air-to-Air, Air-to-Ground and Air-to-Sea capabilities compared to the Elta EL/M 2001 on the existing SLAF Kfir. In the Air-to-Air modes, the radar enables long-range target detection and tracking for weapon delivery or automatic target acquisition in close combat engagements. In Air-to-Ground missions, the radar provides very high-resolution mapping (SAR), surface target detection and tracking over Real Beam Map (RBM), Doppler Beam Sharpening (DBS) and High resolution Synthetic Aperture Radar (SAR) maps in addition to A/G ranging. In Air-to-Sea missions the radar provides long range target detection and tracking, including target classification capabilities (Range Signature (RS), Inverse SAR (ISAR)).
The two remaining SLAF Kfir C.7s will be flown to India later this year, followed by a C.2 and a TC.2 early in the new year.
The second major Project involving India is for the IAF and HAL to upgrade 4 existing SLAF Mi-24V's into the Night Attack Role.
The new upgrade will include replacing the existing cockpit displays to accommodate the ANVIS/HUD-24 Night Vision system. A new composite main and tail rotor, along with a new main and tail rotor hub and gearbox inline with the Mi-35M upgrade. The existing L-166V-1E Ispanka microwave pulse lamp 'Hot Brick' IR jammer is to be replaced with the more capable Ukrainian KT-01 AV Adros IR Jammer field tested to have successfully jammed the SA-18.
This upgrade is planned to begin by the start of the new year.
majorly OT,
Well the info is very impressive...kinada like a script of a hollywood action movie ha ha :lol: some of the info is utterly bizarre and very terrifying for the foes.
Let it be that way so that the enemy will stay behind scared! :lol:
MINIACE
MINIACE
heh heh...but this guy has been quite reliable most of the times in the past :) I think he's an american or something...defa not a local...
and he knows most weapons systems used by our guys really well....quite puzzling...
sorta explains the increased ops taken on by the wolverines in the past couple of months though :)
he he Ripper u got the news as well eh!.. yep the bugger seems quite reliable.. when it's come to that kinda news.. Most of the stuff he said had come true so far.. i mean from the Acquisitions for the SLAF.. I didn't notice that Indians are behind the scene this much!! did you saw the pics?
http://www.lankanewspapers.com/news/2008/5/28503_space.html
Edited by Ruslan
heh heh... do you go by the same screen name on LNP...noticed another ruslan there :)
Yeah I'm going there as the same Handle.. :rolleyes:
Ruslan
used to go there quite often when i needed cheap entertainment but after a while i was also becoming like those morons so buggered out of it :) best thing i've done on LNP :)
Now just go there to checkout white NightFox and Mig29-c is upto :)
Edited by Ripper
Ruslan
Now just go there to checkout what NightFox and Mig29-c is upto :)
100% true. its waste of time visiting other threads. i only too visiting that particular thread only..
