Help Me Choose A Tire From My List (shortlisted)
Here they are for 235/50/18. I am looking for better tread wear and comfort for my daily driver with value for money. Its for a Hyundai Tucson. List is not prioritised.
Bridgestone Turanza GR-80 - Rps 27,000
Bridgestone Dueler HP D680 - Rps 27,000
Kumho Ecsta SPT KU31 - Rps 26,000
Kumho Solus KH15 - Rps 24,000
Falken ZE512 - Rps 23,000
Nankang AS1 - Rps 20,000
What would you pick ? I am leaning towards the Kumho Solus.
Thanks.
Thanks.
MAS are you sure all of these tyres are suitable for a 4x4 ? (I'm thinking Turanza and ECSTA)
this is possibly the best tyre but from an value for money point of view I would go with
Kumho Solus KH15 - Rps 24,000 (If it is the Korean version)
Falken ZE512 - Rps 23,000 (if it is the Japanese version)
was about to ask the same - cuz even the AS1 isn't a SUV tire but rather passenger CAR tire afaik
Also have look at BG Goodridge's Macadam :unsure: series
Michelin have some amazing road biased SUV tires which were ridiculously expensive the last time i checked but worth a lok anyway
last but not least don't for get the Yokohama Geolander & Goodyear Wranglers
look for a road biased tire series but made for SUV use - i wouldn't recommend the tires that you've put us seeing as most are quite simply car tires :mellow:
Thanks for the feedback.
I do not go off road - strictly normal driving and my Tuc is a 2WD.
I have also checked the loading capacity and all listed tires are within specs.
Cheers.
  • 1 year later...
Cheers.
There is a very disturbing humm generated from the front tyres. This is a 4WD Tucson which does much of the driving on poorly paved roads. The humm is very prominent when driving on carpet roads.
After a lot of inspections the agents told to replace the tyre as the grove depth, tread pattern and wear resulted in the noise. Any suggestions?
Bridgestone are the best :rolleyes:
The Bridgestone tyre tread pattern is not recommended and its more grooved than Dunlop tyres.
Originally it was Kumho, then changed in to Dunlop. Now it is a Michelin set. The car has done only 125000 Km.
When the tires do around 25,000 the humm becomes more audible.
