January 24, 200917 yr It's a Suzuki Escudo 2000 model, 2 ltr petrol engine. When i push on the accelarate, engine RPM drops down slightly and then increases. This is annoying as i feel a delay in response when overtaking, etc. Will an engine tuneup solve my problem/
January 25, 200917 yr It's a Suzuki Escudo 2000 model, 2 ltr petrol engine. When i push on the accelarate, engine RPM drops down slightly and then increases. This is annoying as i feel a delay in response when overtaking, etc. Will an engine tuneup solve my problem/ Is yours an Automatic or Manual transmission?
January 25, 200917 yr assuming its an Auto , your Automatic Transmission Fluid could be due in for a change.. Edited January 25, 200917 yr by Devinda_Z
February 3, 200917 yr Author assuming its an Auto , your Automatic Transmission Fluid could be due in for a change.. Thank you for the reply. Yes it is an Auto, but it happens even in Parking position at idling speed. So i doubt this is the problem. any other suggestion?
February 3, 200917 yr Thank you for the reply. Yes it is an Auto, but it happens even in Parking position at idling speed. So i doubt this is the problem. any other suggestion? Throttle Position Sensor issue perhaps?
