I have a CR41 Diesel and since about two weeks it suffers from a starting problem in the morning no matter how many times i heats it up and tries,However around 10-11 AM it starts after few attempts and after that it simpy starts without a problem for the rest of the day.
I changed the injector nozzels about two months back and the very first day after that it didnt start as well so i asked my mechanic to have a look at it and he removed the nozzels and did something to it and later the problem was resolved until two weeks back.
The first thing i suspected was the heater plugs and he said that they are fine,However i also noticed a small oil patch on the engine and when he checked that out it was coming from a small tube that leads from the engine to the air intake and the mechanic guy checked that and noticed some oil in the air intake hose.The guy then said that the oil is coming from the "under air hose" and i need to replace the piston rings or do an overhaul.
The vehicle has run about 225k and the fuel consumption is about 12-13 with A/C in colombo and about 15 outstation with A/C.I see some smoke when i start the engine in the morning only and later when the engine heats up the emission is very less.
Can any of you guys advice me on what i should do to fix this problem.
I have an empty parking slot at home previously occupied for 6 years by the starlet and 3 months by an AD wagon -what would be a bang-for-the-buck fun shitbox? Preferably auto as I live in a crowded suburb that has sapped the joy of stick shift out of my system.
jellyfish
Hi Guys,
Thank you
1 answer to this question
