hi guys
i own a suzuki swift 1.3 manual R type made in japan
recently i did the engine tuning at rajagirya
i saw when i put in the ignition key and turn on the car( not going the full circle and putting the car on to first gear ) the TACHO METER IS already showing some reveloutons around the 1.5 mark
is that normal or is it due to the tuning
does it rduces the fuel efficacy
any ideas guys
At the normal working temperature, Idle RPM should be 700-800. If it is 1500 at the time of starting in the morning, it is ok but it should come down once engine gets heated up.
