I drive a '87 Toyota Starlet EP71. I have done a overhaul on the engine (which is in absolute stunning condition now) but I seem to have a ongoing prob with the carburator. Through what I have heard the EP71 uses a quite 'complicated' carb.
The engine hardly runs when its on idle (i.e - it just runs as if its out of breath, varying the rpm up and down and then the jerks and stops). Also I've noticed that the engine runs for a couple of seconds after it has been turned off!
Now I've shown this to a couple of mechs and they basically tell me that the carb is clogged, since the EP71 has some 101 lines and nozzles. A temp clean up always works but is there any permanent solution for this?
I have my own three and I need a bit of advice..
1. Change the carb, which might be a good option, but I've had no luck finding one. (How much will one cost? if there is one)
2. One mech said that I can swap it with the normal carb... Will this work? or would it have any side effects of my cars performance?
3. Could I do an EFI conversion? (is it complicated and costly?)
Hope someone could help me!
Cheers!
Apart from this could I install a turbo kit whilst attending to my carb issue - how practical is that?
Surrounded by various different nice car models in Germany but still fascinated by the Presea, Bluebird U13 and the Mark II.. The first cut is the deepest.. Baby I know, the first cut is the D he he he
megatron
Dear experts,
Cheers!
12 answers to this question
