posting this for a buddy who is not a member at AL
Quote
I have a problem with my clutch. After excessive use (eg: being in a traffic jam for about 30 min), the pressure in the clutch pedal disappears. It starts to freely depress (absolutely no give) and come back up on its own. Obviously i cannot engage the gear. After the car cools or about 2 -3 hours later, the clutch works fine.
The chronology of problems is as follows:
1/ May 2008: the problem first appears. Sudath in Kalubowilla replaces my upper and lower clutch kit. Problem sorted.
2/ Feb 2009: the prob happened again. Wasantha - in Borella - changed the washer in the clutch pump. Problem sorted.
3/ May 2009, faced the same issue. This time, Wasantha removed the gear box and welded/fixed the clutch fork which was damaged and replaced the ball bearing. He clearly told me that there wasn't a problem in the clutch plates.
4/ June 2009, it happens again. Wasantha removes clutch pump, looks for leaks, and after failing to find anything wrong, replaced the washer again. The clutch seemed fine until afternoon of the same day. I had been in traffic and the clutch gave in again. This time Wasantha reduced the play in the clutch. Unfortunately, till now, the problem has not gone away.
I don't think that Wasantha has any more solution in fixing this issue. But it needs fixing. Driving the car for long durations or in traffic is a nightmare. Is there any person out there who could give me a solution or point me to someone who can?
Surrounded by various different nice car models in Germany but still fascinated by the Presea, Bluebird U13 and the Mark II.. The first cut is the deepest.. Baby I know, the first cut is the D he he he
What is the deal with the car market these days!!
I went to check on a Jimny, 2016 2nd owner and he's hellbent on 6.8mil for the thing,
approx 50000km+ mileage
Needs tyres, rear shock absorbers leaking and there has been an aircon repair as well.
(Approx 400k LKR in pending repairs making the total 7.2mil)
Whereas a brand new one can be imported between 8.2-9.5 given the grade and winning bid.
I ponder what the mentality is of the people of this country...🤣
Ripper
2 answers to this question
