Steam Come Out From Dash Board
I HAVE EE96 TOYOTA COROLLA WAGON. AND PROBLEM IS AFTER 2, 3 KM ITS STARTED TO COME OUT STEAM WITH THE SMELL AND NOISE FROM THE DASH BOARD ITS JUST LIKE A FIRE . WHAT SHOULD I DO
9 answers to this question
I would RUN first..... :jumping-smiley-013:
but then it could be a busted heater element pipe inside the dash. You really ought to be taking it to a garage ASAP as you will have a coolant leak inside the car.
yep...take it to a garage and have it looked at mate!
yes i notice that coolant also reduce by about 1 1/2 bottle. how steam come out from dash board ac is working properly
because the busted coolant pipe is hemorrhaging the coolant in to the AC! Get it checked before you have a overheated engine or worse.
yes at that time heater meeter come up to middle, but normally increasing heat is not resulted that way no. i hope its come out from radiator side. But i have little doubt about radiator cooling system also. Are you think its require Radiator service as well
I will not waste time speculating and get it to a good mechanic asap
normally a coolant system hose goes via the dash board inorder to give hot air when u on the heater. so my guess is that the hose going inside the dash board must be havng a cut or a small hole in it. anyways check it out asap or its gonna end up in a big mess!!!!
Dear Friends
Last evening i went to AC repair man and he bypass the heater line which connected to the dash board wall. very small repair at least he didn't taken any money. will c the result later i hope problem is over.
thanking all of you
