I drive an old Mitsubishi with a 4G15 carb engine.
Here's how the problem goes:
when I start the car, it performs really well, but after using for about an hour or so, the performance drops a bit:
such that I have to accelerate/rev more -
for example, I have to rev to 2k to 3k RPM to get reasonable performance in gears 2 - 4 - performance with AC is particularly sluggish.
(when the car is started up I can use any gear comfortably under 2k RPM).
Its like the car suffers a loss of power after it is used a bit.
If I pull over and leave the engine running idle, or even off for about 5 minutes, the power sometimes returns to normal.
Notes:
car does not overheat, engine temp management is good/radiator etc, good
I got the carb serviced by a garage (or at least, they claimed they did) and various other stuff done (fuel filter, plug wires, etc)
I've tried various mechanics, none seem to have any suggestions. One guy believes its something to do with vacuum or something (don't know what he means)
Personally I strongly suspect it is something to do with the carb, as - if I tweak the carb, a bit (say, adjust the mixture nut a tiny bit) suddenly it works well.
I remember someone here mentioning someone who fixes carbs... could someone tell me where that guy is located?
also, could the problem be timing related? tweaking the timing a bit sometimes helps, but then the car slowly gets worse again.
Officially joined the thel-hinganna normie horde with ....drumroll... a 2025 Vezel... I am eagerly anticipating joining the 'thel keeyak karanawada' debates at almsgivings.
Recently, got the opportunity to see and get inside of The one and only Japanese V12, Toyota Century(a.k.a Japanese Rolls Royce). Is it really upto Rolls Royce standards? Nope, I don't think so. Items like Switches and mirror housings are in plastic. But, we can be assured that the dashboard will not light up like Christmas and would run forever....
Saturn
Notes:
Edited by Saturn7 answers to this question
