No offence to the seller, but did you guys notice that the same owner has advertised a Grand Civic Sedan some time back. There also he mentioned "used as second car" In that case how come this also is "second car?" Shouldn't it be third car :D
well he must have sold the old one man... DUH...
but that's a nice hatch if I must say...
I agree with you on that Dragster, It is a nice looking car. I called up the owner, but he didn't answer the phone. How much will it be worth?
no idea.. there was another one advertised, that was a 19- i believe and it was in the 800k range...
what is the market value on these?
Anyhow this is a good promotion for this Grand Civic Hatch..
By the way demand for Grandcivics are very high these days. if you're a Honda fan im sure you love that model.
Cheers.... :D
max.so the owner is not answering..did u check the photo dates ha ha 01/01/2004 mate thats over 2 yrs old or something wrong with the camara..ha any way dragster/mad max if u got a chance between a grand civic hatch n the crx..(both 1990 model) what would u select..with body style..engine n specially with performance n handeling n the best engine u can swap to it( sohc v tec 1500 or 1600 is hot fav)....fuzzo u can't answer this..(ha ha u know y!!!)
The CRX anyday.. :action-smiley-060:
Is this a race type hatch?
yep can race up with few changes but depends on eng cap..cos this comes as 1300cc n 1500cc(model ef1 n ef2)..well the crx is a straigh fit to 8-10 n even 6-8 with eng mods (janaka dias runs both events with 2 crx's ..both same colour..hard 2 separate 1 from 1).. alredy there r few grand civic hatch in racing in the event sl_a cars upto 1400cc fighiting with the mighty fully mod kad mini of y@ga p#re#a n susuki caltus..i'm wondering can this be run on 10-12..pila what do ya think?
:action-smiley-015::sad-smiley-023::wacko:
:rolleyes::rolleyes::rolleyes:
well CRX is a major hit all around the world from what i gather from browsing, but in foxhill i noticed that CRX oversteered, looked as if itz to do wit da car than the driver, may be CRX is good on straight line and not so good on curves, any ideas?
Machan Hola will u be comin 2 G2G today?
The CRX anyday.. B)
You got to check out this article about this ledgendary SiR hatch
http://asia.vtec.net/featurecar/EF9/index.html
Model Code : E-EF9 Civic SiR
Engine B16A
Configuration 16V PGM-Fi DOHC VTEC
Displacement 1595 c.c.
CR 10.2
Max Power 160ps (118kW) at 7,600rpm
Max Torque 15.5kgm (152 Nm) at 7,000rpm
RedLine 8,100rpm
Transmission 5MT only (with option viscous coupling LSD)
Gear Ratios 3.166, 2.052, 1.416, 1.103, 0.87, R=3.000
Final Drive 4.266
Kerb Weight 990 kg
Dimensions (LXWXH) 3,995 X 1,680 X 1,335 (mm)
Wheel Base 2,500 mm
Track F=1,440mm R=1,445mm
Ground Clearance 150mm
Wheel Size 195/60 R 14 85H
Suspension (F) Double Wishbone
® Double Wishbone
Brakes (F) Ventilated disc
® Solid Disc
Anti-roll Bar Front and Rear
1400 modified Group A's the way to go. Dont think it can 10-12 cause of the low weight
the b16a2's was the most popular.. 170hp with higher C/R
