Hi
My car starts shake on driving. recently i replaced front hub and Lawer arm bush. it was fantastic for 4 weeks time. now got this issue. i also relized the left side front and rear Shock absobers are bad. is this the cause for shaking?
Also advice me replacing Second hand shokabsobers? are they good?
Let me see your views
Sira
Hi
Sira
Did you check alignment after the repair?
Yes i did
Once I had a similar issue because the inner wires (or cables or whatever and the tire shop guy was saying "ethule thiyena kambi) of one of my tires were broken. The ride was quite bumpy because of that. Also is this jerk coming only in the 1st and 2nd gears? If so, it can also be attributed to a bad clutch and pressure plates. I guess the reasons can be many and we can only guess. So I think you should show it to a good mechanic.
Edited by L board
I also think its tires. Check all your tires carefully.
Edited by Sha7
