Since the day i got the vehicle, i feel it.. it's little difficult to put the gears. Specially 5th and reverse gear. Also its speeding up well but less pickup. Is this same setup issues or.? what do i need to check..? :unsure:
Check the foll: Clutch Plate, Pressure plate, Cluth Washers...(Devinda and I experienced this first-hand at the Classic Car Rally last Sunday) and possibly the Links.
  • 3 weeks later...
you should check the clutch oil levels first. if it is used to go down, check the oil seals. or oil patches on the floor of garage. i hope there should be some thing wrong with the clutch. so check it from a good place.
Thanks Guys, i'm gona check it this week end.
  • 6 years later...
Guys I'm having Nissan FB-15 (2003) and clutch plate n pressure plate giving some problems and need replacement.
Your ideas about following issues are highly appreciated.
1. I'm thinking going for a genuine Nissan spares, But as per A*W, only the clutch plate would cost around Rs 18000. In the same time I can buy "made in Japan" spares (full set clutch +pressure + bearing) for under Rs.15000 from outside. So is it really worth going for a genuine Nissan parts ?
2. Is Pitst0p good for such repair ? Or else any suggestions ?
Thank you.
Edited by Thilina007
What was the brand of the Japanese kit they offered you for under 15K ? Aisin ? Valeo ?
Thank for the reply.
There are two brands  " STD " and " Vaiken " (I am not sure about the spelling this how they spelled out) both are 10000 to 15000 rage.
I think those were Exedy (not STD :P ) and Daikin,
Exedy is an excellent replacement brand and the 2 companies are connected in some way as far as I know. Make sure you match the correct part number with the genuine item.
My bad :D :D
Thanks for the info Bro. So the best option is going for the Exedy. isn't it ?
Any recommended place around Colombo area to do the repair ? Pitst0p okay ?
