sira Posted May 17, 2010 Share Posted May 17, 2010 Hi Any body know where can i buy FB 13 (1992) doors. i need to buy 2 doors of right hand side sira Quote Link to comment Share on other sites More sharing options...
Ralph Posted May 17, 2010 Share Posted May 17, 2010 Second hand right? I got 2 door for my FB 15 few months back. Cost =14K both . @ S#lva Motor H#use, Negambo. Call this no n ask them : 031-5318834 Re Quote Link to comment Share on other sites More sharing options...
ae100 Posted May 17, 2010 Share Posted May 17, 2010 If I were you, I would have a walk from the Wijerama junc to Delkanda junc peeping into every shop and asking "Doctor Sunny dorawal thiyenawada?. keeyada?" and if they have, inspect the stuff. finally go back to the cheapest place and start bargaining. Since you are buying 2 doors, you should be able to get a good bargain. By the way, if the inner parts of the doors are intact (the winders, locks, glass etc) then try to get only the metal parts (better to discuss with your garage first, as it would be double the work to remove your original parts and re-fix) and this way you should be able to go for a better bargain. Good luck..!! Quote Link to comment Share on other sites More sharing options...
