June 21, 201016 yr observed that uneven wast outer layer of front Tyre, pls advice Thanks Can you give a bit more info? what sort of vehicle is it car/van/jeep?? Have you had the alignment checked? It can be improper alignment casued by a range of faults on the suspension. get your suspension checked by a good garage most probably your suspension arm bushes/ball joints need replacement.
June 21, 201016 yr observed that uneven wast outer layer of front Tyre, pls advice Thanks Incorrect Wheel Alignment. Do a proper wheel alignment ASAP.
June 21, 201016 yr Author First of all thank you so much for immediate reply, this is the car EE 96 corolla wagon 1991, wheel alignment not done for long a period and didn't check the suspension system.
June 21, 201016 yr You got you're answer right there First of all thank you so much for immediate reply, this is the car EE 96 corolla wagon 1991, wheel alignment not done for long a period and didn't check the suspension system.
