How to remove dashboard minor scratch.. When mechanic remove burnt bulb on dash board, he accidently scratch the dash board
Won't be easy specially if the scratch has penetrated the top coating. You can try to wax it off.. but failing which you might need to do a paint touch up.. i did it for mine.
if its just a barely visible surface scratch which can not be felt upon touching it, then some Brasso or Signal Whitening toothpaste might be able to do the trick - both are great for discolorations, swirl marks & such small scratches
Signal whitening?? :blink: How does that help?
