Brake, Engine, Battery Warning Lights Continuously On
I have Toyota Corolla CE96 Diesel 1991 Station Wagon.
Last week suddenly i got Brake, Engine, Battery warning lights continuously ON.
Any idea what may be the cause .......?
Is it due to alternator issue or something else ?
thanks.
I just went to an auto electrician. He said seems alternator is defective, since battery charging voltage is below 12v.
He said need to remove the alternator and see.
So i have to keep my car there and come back. :(
After came home, I checked are there any alternator repair mannuals in the web, just to get an understanding of how it works...
Fortunately i found below from Toyota USA.
It's very informative, therefore thought sharing it for you all.
www.autoshop101.com/forms/h8.pdf
Hope this may useful.....
thanks.
never heard of a brake warning light flashing when the alternator is faulty...are you sure their not ripping you off?maybe it's just a problem with the wiring...
The alternator has a vacume pump and if the alternator is not performing good ( rotation) charging as well as brakes dont function well.
This seems something with the alternator drive system, and not electrical something, check the drive belts.
