Dear Experts, I want your advice regarding ATF
I had my ATF changed at p**stop about month ago on my ht51s (Suzuki swift). They insisted that i do engine flush, throttle body clean etc.. and I allowed all that to be done. After that I feel that there is much vibration in the car, especially when its in D and break is fully depressed. I also checked ATF level and noticed that they have overfilled it. The level of ATF was about 1 cm above the max level when engine was cool and not running.
Can the vibration in D caused by overfilled ATF ?
I'm going to take it back to p**stop tomorrow. Is their any other place for Auto transmission diagnosis ?
regards
Edited by Thiwanka Wimalasuriya
yes.
you can first send a comment from http://www.amwltd.com/pitstop/html/comments.htm and explain how you got the check engine problem just after the service. You will get a call from management within a day. I think you should also demand a FOC fix, if you believe that the service caused the issue. (I did same)
Thanks a lot, did post a comment. Looking forward to the call.
A*W guys was forcing an engine flush which I refused.
But if you look at my service bills my EJ 15 has taken 4 liters, another time 4.25 liters and the last time 4.5 liters of engine oil.
They are used to ripping off maruthi customers who are new to cars.
A#W really isnt doing well on on the forum, and this is just for their poor service... not even relating their cheapo marketing tricks form some months ago...
Edited by Dilesh
Glad to hear it's now fixed. I'm surprised that a dirty throttle body would cause the problem you're having, but if it's fixed then good.
Forget A*W, think I'll switch to BMW.
