Hi friends
I am intrested in buying Honda EG8 to have some good driving expierience(as second vehicle)
Its so good looking and affordable
But i dnt no what are the common issues with it and the fuel consumption.
What is the difference between Ferio and other models
Whats the market of a EG8 with a vtec engine?and what are the common probs with Vtec eng
Need your expert opinion on this please
Has been discussed 1001 times before, try the Honda section ;)
And anyway look for anything and everything like you do for anyother car. And if your asking specifically about the Vtec engined car? It's an EFI, so look for the CEL. Fuel consumption, you don't have to worry if the internals are in right condition and maintained. And afaik all JDM EG sedans were Ferio? Atleast Vtecs? but i don't know. Go ahead, buy it!! :D
try to avoid modified cars.. most of the modified cars not in good condition.. thats my experience.. :)
agree with Kalana.... but its really rare to find a very well maintained EG8 at a reasonalable price these days... most of them r either hacked or not i good condition...
well internal condition is a must...
VTECs are good in fuel. 10-12 with AC... i use a carb model.. it doe about 9 - 10 with AC.
there is a problem with Egs that water coming in to the car.correct me if im wrong jumper. :unsure:
Me too having an EG but it dn't hv any issue like dat. May be some issue with ur cooler i guess
Absolutely true :P
If u wanna more power, better to hang on with vtec or dual carb version. single carb version is bit underpowered in high rpms. Since this is ur second car, EG6 is the ideal deal ..But those are very very rare & pretty expensive too.
Edited by overTuned
most modified cars are maintained by Honda lovers & they take good care of their cars,sometimes far better than ones that are not modified.in a nutshell,if the car is well maintained,buy it if it's modified or not.
Edited by Nitro
did u check ur ac water pump?? or is it from the doors?
most modified cars are maintained by Honda lovers & they take good care of their cars,sometimes far better than once that are not modified.in a nutshell,if the car is well maintained,buy it if it's modified or not.
I would thing all these modified cars are ones that you should AVOID. There are 2 typoes of modifications, cosmetic and mechanical.. those that are mechanically modified are done so for a reason. That is to be able to thrash the cars down green path or some other mean fo racing.. and those THAT HAVE cosmetic modifications are quite often tasteless and done with heavy fiber-glass (no doubt the person doing this had no idea on the negative impact it had ont he car, hence kinda uneducated about car-maintenance).. I'm not saying that this is the norm, but IMO you're better off (reliability wise) buying a car that look plain-jane than all blinged up...
theres no prob with ac water pump jumper.when theres rain water coming to the front leg space area.it was raining last night n when i check in the mornin under the carpets was wet. :o
make sure the rubber beading between the windscreen and the plastic cover thing underneath the wipers is in good condition. If water leaks through that for a long time it could form rust around the lower part of the windscreen which would everntually lead to water leaks..:)
Edited by GearHead
you are right GEARHEAD.i put water on to the windscreen n checked.water going through the windscreen n that plastic cover.some areas of the plastic cover not fit to the windscreen wel.there are gaps.actually theres no a beading.what can i do for that Gearhead?replace the rubber beading?
thanks in advance :)
Edited by hashanfernando
you are right GEARHEAD.i put water on to the windscreen n checked.water going through the windscreen n that plastic cover.some areas of the plastic cover not fit to the windscreen wel.there are gaps.what can i do for that Gearhead?replace the rubber beading?
Could this happened in EK3?
