yohanaz Posted September 16, 2010 Posted September 16, 2010 (edited) Dear friends, Need a help regarding a Honda Civic ES8( Y.O.M 2000) . There is a sound coming from my cars front wheels when going on a rough road... As per one of the mechanic i was told that Bush in front wheels has to be replaces.... Please advice me regarding this........... is it the bush ? or something else...... Thank you Edited September 16, 2010 by yohanaz Quote
TURBOMAN Posted September 16, 2010 Posted September 16, 2010 May be CV joints its a common problem in ES8 Quote
yohanaz Posted September 17, 2010 Author Posted September 17, 2010 check shock mounts as well thnx for the reply i was told that it might be the bushes infront wheels ... can it be ryt? and if i have to replace them what would be the best way... thnx Quote
jaga Posted September 17, 2010 Posted September 17, 2010 thnx for the reply i was told that it might be the bushes infront wheels ... can it be ryt? and if i have to replace them what would be the best way... thnx What bushes u are reffering to? Probably following reasons it could be. * Shock absorber dampers * Lower arm bush * Rack ends * steering rack If shock absorbers are weak, you may have to replace and cost for both aprox 20000 Rs Lower arm bush cost you 1500 Rs-2000 Rs (I have changed in mine some time back) Rack end s cost ???? Steering rack isuue has a temp. solution to introuce a nylon bush if not u have to go for a used rack cost about 30000 Rs. Brand new rack cost u more than 1 lacks. Instead of nylon if you could find TEFLON, It will last longer. Quote
yohanaz Posted September 17, 2010 Author Posted September 17, 2010 What bushes u are reffering to? Probably following reasons it could be. * Shock absorber dampers * Lower arm bush * Rack ends * steering rack If shock absorbers are weak, you may have to replace and cost for both aprox 20000 Rs Lower arm bush cost you 1500 Rs-2000 Rs (I have changed in mine some time back) Rack end s cost ???? Steering rack isuue has a temp. solution to introuce a nylon bush if not u have to go for a used rack cost about 30000 Rs. Brand new rack cost u more than 1 lacks. Instead of nylon if you could find TEFLON, It will last longer. Thnx a lot Jaga for ur reply its really helpful Where can i replace the lower arms bush except for stafford ? can it be done in one day? Quote
