My 2001 Suzuki Swift Suddenly started to give trouble, this is what happened
1 - Started the Car (Not sure whether the Battery Charge indicator was on), no problems it started normally.
2 - When went on to the road, the Battery Charge indicator started to Flash
3 - ABS indicator switched on
4 - Air Bag Indicator Switched on
5 - EPS Indicator Switched on
6 - I stopped the Car, and could not start again
7 - Started the car with a Jumper, the vehicle was ok, started with one stroke (Not sure whether the Battery Charge indicator was on)
8 - After a while 3 - 5 happened again
Started the car with a different Battery, car started and the Battery Charge indicator was off.
Checked the Battery the level of fluid is below the minimum level,
Is this the normal behaviour of this car when the battery is dead ?,
I ran about 10km in the morning with out trouble and the car started without any problem in the evening, before stalling in about 15 mins. how is this possible ?
The vehicle had a 'creek' noise coming when I start the car in the morning and in the evening, and I checked it up and the belt was tightened, a week a go, but the 'creek' noise stayed. and now before and after the problem I do not get the 'creek' noise when starting the car, may due to a faulty battery ?
AMI0755
Edited by AMI07555 answers to this question
