Hi guys,
I am new to this forum and this is my first post here. My car is a Honda civic ES8 2002. Except that regular service from Stafford Motors what are the other things i have to do as regular changes. I am checking oil and water levels after three/four rides. I have heard/read that it needs gear box oil changes too .If yes when and how can i do this. Is it done with regular service at company or do we need ask from them to do this? Also are there anything else that i have to keep checking/changing?
Thanks in Advance
ES8 with CVT gear box?? then the regular oil changes is a must mate..agents recommend it to be done for every 15000 km..check when your last CVT oil change was done?
Edited by Hiran690
Hi guys,
Thanks in Advance
Is it an Exi or a VTI?
If its a VTI U'll need to change the CVT oil every 15k Kms as said by Hiran
Its an Exi. But not a brand new car. Imported from Singapore. Bit different from other Exis i have seen so far. Got nickle handles etc. Checked available service records and they says i have gone 13000kms after last AFT change. Thanks for all the infor given.
Welcome,
If it's an Exi I dont think that you should worry :)
Welcome,
Bro note..that is a Singapore import .... Singapore EXI normally has the CVT since 2001... jus check whether u have these gear positions respectively...
"P" - "R" - "N" - "D" - "S" - "L" if you have these... then that is a CVT tranny ! else its not...
YES..check IMMEDIATELY whether there is a S gear position..since you have mentioned that an ATF change was done 13000 km back.. and if you have done an ATF change to a CVT that scares me big timeunsure.gif
Edited by Hiran690
Thanks Again for all the infor given. I am scared to here the last comment.
"if you have done an ATF change to a CVT that scares me big time"
What does this actually means?
