Hi Guys,
One of my friends bought a Pajero Gdi(98 model) recently and i also had a ride
Very comfortable vehicle,BUT
1.When i speed it up above 80km/hr it went into a side ways oscillatory movement(the best way i can describe that motion) which was little bit hard to recover.
It disappeared when i slow down
2.When turning to the left side,theres vibration felt on steering wheel.
3.abnormal sound coming from front wheel unit when climbing hilly roads
Please give your expert opinions in this trouble
Hi Guys,
I guess wheel alignment and balancing would solve the problem :)
Hi Guys,
Check the wheel alignment and balance as suggested and also the Tyres..... what you described also happens if the steel wires inside the radial tyres
have broken due to age or due to hard driving with insufficient air pressure.
Hi Guys,
Thanx my friends
The tires are in good condition.
It may be the Wheel alignment or the weak ball joints as you have mentioned.
I will check them
ill give you a feedback.
Thanx my friends
I will check them
And check your both hub razers(bearing) too.i've faced the same problem and my issue was that..
Thanx my friends
I will check them
Turbo,
Check the rack ends/bushes + CV joints and Steering joints.
If the engine makes noice in higher rpms then it might be engin mounts. :alc:
Turbo,
Thanx my friend,
Ill definitly ask him to get them checked
Do you know a good place for repairs ,or else should go for agents?
Pajero io is a piece of Crap. :violent-smiley-099:
I guess your speaking through experience right? Once again here's another new idiot on this site putting out random sentences of bulls***.
