:: Need Help With Projectors ::
Thanks, but im not that a mechanic guy to do it myself, I dont have the right tools i guess. Machang by using this sealent will it burn the plastic? The light looks awful now. I am now regreting it
Yes, leak proof should be a gurantee for anyone who is intrested in projector lamps. :angry:
Don't worry.... you don't have to be a mechanic to do all that. Few simple tools would do that. Silicon sealant or the Windscreen wonโ€™t harm the plastics. If you are going for the Silicon use the black one. It's better than the clear silicon. Silicon can be removed at any time without any hassle, but the windscreen sealant is messy but results guaranteed.
nishantha's workshop is at karapampitiya. come up hill street and before amila's tyre shop, turn left towards the zoo. go past the market and temple and ask around there for nishantha. anyone will show you.
sealing with silicone will fix the problem.
nishantha sounds familiar is this the short fat guy with thick glasses?????????
Fuzzo, will this cost a lot? Sure he wont harm my plastics?
i don't know the cost. you will have ot ask him that. the silicone will not affect the plastic. you can remove it quite easily.
Ok will go soon before water gets filled up and the lights get burnt
dude are you nuts to go to dehiwela all teh way from negombo. just go to an electrician he'll do it 4 you. you'll be able to find one in a normal garage
machang, heard that dehiwala man is the expert....
put a 90 degree drain tube (like the ones u get in the bumper lights). DONT try to seal the unit unless u can guarantee that water wont get in (other wise water vapor has no where to go once it gets in). If you really wanna seal it, put it an oven get it hot (close to 100C) then when your sure all the water is out seal it with silicone. (be careful not to get it too hot-I've melted a few making clear lights). IMHO, put a drain tube and let it breathe, the air inside needs to expand anyway...
btw, are you talking about HIDs or just hallogens?
