ThunderBolt Posted October 29, 2007 Posted October 29, 2007 Hi all Could someone tell me the name of the thick paint they have used in MAZDA and FORD cars for gravel and corrosion protection? Mostly seen as a think line of paint. Quote
The Don Posted October 29, 2007 Posted October 29, 2007 I think its under seal isn't it, applied on all motor vehicles ? Quote
milindu Posted October 29, 2007 Posted October 29, 2007 Hi all Could someone tell me the name of the thick paint they have used in MAZDA and FORD cars for gravel and corrosion protection? Mostly seen as a think line of paint. Most cars from Singapore come with an undercoat called Tuff Kote offered by Kle@n P@rk. Both ICI and Wurt# Lanka offer Underseals and Corrosion Inhibitors that go under such coatings. Most of the better paint guys will be able to do the application. Quote
Arc Angel Posted October 30, 2007 Posted October 30, 2007 Most cars from Singapore come with an undercoat called Tuff Kote offered by Kle@n P@rk. Both ICI and Wurt# Lanka offer Underseals and Corrosion Inhibitors that go under such coatings. Most of the better paint guys will be able to do the application. is this stuff only for the undercarrige? Quote
milindu Posted October 30, 2007 Posted October 30, 2007 is this stuff only for the undercarrige? They have different types of coatings (both paintable and non-paintable) for different applications ranging from anti-corrosive to sound reduction to protection from gravel etc. Can be applied at different areas. Wurt# also did a demo with their sound reduction sheets last week. Its like a thick resin rubber sticker and does wonders for most non Euro cars which lacks insulation from road noises. Quote
Arc Angel Posted October 30, 2007 Posted October 30, 2007 They have different types of coatings (both paintable and non-paintable) for different applications ranging from anti-corrosive to sound reduction to protection from gravel etc. Can be applied at different areas. Wurt# also did a demo with their sound reduction sheets last week. Its like a thick resin rubber sticker and does wonders for most non Euro cars which lacks insulation from road noises. bet the soundproofing increases the weight alot though... mahcan any idea how much a paintable coat of anti-corrosive would be? Quote
ThunderBolt Posted October 30, 2007 Author Posted October 30, 2007 that paint is not underseal. it comes only in MAZDA and FORD cars. looks like thick layer of Multibond gum on the normal body paint. I have marked the area that paint appears. Quote
The Don Posted October 30, 2007 Posted October 30, 2007 that paint is not underseal. it comes only in MAZDA and FORD cars. looks like thick layer of Multibond gum on the normal body paint. I have marked the area that paint appears. Inside the door or the outside ? Quote
ThunderBolt Posted October 30, 2007 Author Posted October 30, 2007 (edited) both outside and inside. this paint line is clearly visible to all in MAZDA 323 and FORD models (latest models). this paint appears not only doors, entire area that i have marked. Edited October 30, 2007 by ThunderBolt Quote
Bugatti Posted October 30, 2007 Posted October 30, 2007 I'm not sure it is available outside... I too was searching for it (for my Mazda) as I need to fix a dent on the side.. it's more of a protective layer against tar and mud scratches.. If u do locate a place to buy it, pls do let us know.. Cheers.. Quote
GearHead Posted October 30, 2007 Posted October 30, 2007 is this stuff only for the undercarrige? hi milindu, machang how much would it cost to get this sound insulation done on a 4 door family car(a honda EK3)..thanks in advance.. Quote
milindu Posted October 30, 2007 Posted October 30, 2007 hi milindu, machang how much would it cost to get this sound insulation done on a 4 door family car(a honda EK3)..thanks in advance.. I will check with the supplier asap and get back to you. There is a transparent 3M Protective film which can be applied on the side balances or at edges that tend to chip. Quote
milindu Posted November 5, 2007 Posted November 5, 2007 hi milindu, machang how much would it cost to get this sound insulation done on a 4 door family car(a honda EK3)..thanks in advance.. Wurt# quoted as follows Floor Board Sheets (Looks like self-adhesive thara sheets) - 1 metre x 1/2 metre - Rs. 3100 (Rs 2950 for over 4 sheets) - A full job on a car will need about 5 sheets. It might be worth just doing the front area only. Compressed panels with foil layer - 10" x 22" x 6 sheets per pack = Rs 4800 - This is meant for door panels, firewall and bonnet areas with additional heat insulation. I think the McF*il sheets might be a much cheaper alternative. Quote
GearHead Posted November 5, 2007 Posted November 5, 2007 (edited) thanks a lot for the info machang.. Edited November 5, 2007 by GearHead Quote
GearHead Posted November 5, 2007 Posted November 5, 2007 just a question,does this sound insulation really work? its a lot of money that they are charging for it, so its always better to know whether it really works. have you guys even driven a car which has WURTH sound insulation? Quote
milindu Posted November 5, 2007 Posted November 5, 2007 just a question,does this sound insulation really work? its a lot of money that they are charging for it, so its always better to know whether it really works. have you guys even driven a car which has WURTH sound insulation? I got a thick coat of the underseal done which made a slight difference. Just got introduced to the sheets recently. So unable to comment on that. But its this type of insulation that gives the Euro cars that no fatigue feeling to some extent. Sealing off openings that wires and other parts pass through is the most effective way to cut noise. Quote
Sparky Posted November 6, 2007 Posted November 6, 2007 Wurt# quoted as follows Compressed panels with foil layer - 10" x 22" x 6 sheets per pack = Rs 4800 Hi Milindu, Where can I find this? Are these panels self adhesive? Quote
Sparky Posted November 6, 2007 Posted November 6, 2007 (edited) Sorry, double post. Edited November 6, 2007 by Sparky Quote
ruwan67 Posted November 6, 2007 Posted November 6, 2007 Hi all Could someone tell me the name of the thick paint they have used in MAZDA and FORD cars for gravel and corrosion protection? Mostly seen as a think line of paint. if i reply for correct understanding of the requirement. There is a special primer coat call rust converter which is converted rust the corrosion in to filler so no need brushing and it seal the body. It is use for many places and I heard from the sales ref that it was invented by BMW. I forgot the company name but he told me he is supplying to dot-Dumi##a the car modifying guy. for cooling tower pips we purchased from Will Power the chemical supplier Regards, Ruwan Quote
ThunderBolt Posted November 13, 2007 Author Posted November 13, 2007 Hi all Is there a sticker available in the market to protect plastic parts near the door from scratches caused by shoes? if so let me know the place to buy it. Quote
Ruslan Posted November 13, 2007 Posted November 13, 2007 (edited) Hi all Is there a sticker available in the market to protect plastic parts near the door from scratches caused by shoes? if so let me know the place to buy it. I used to cover those Plastic panels (In Corolla 121... since the interior beige colored, tends to get dirty all the time ) with thick polythene and blow it with hot air gun.. that will cause the polythene to wrap it around the Plastic panel. this way you can clean the plastic panels very easily. you can even get this done by those "cushion work" guys.. there are couple of shops down at near "Delkanda pola"(Near Nugegoda) area. Edited November 13, 2007 by Ruslan Quote
