dhp
Everything posted by dhp
  1. dhp replied to lasa's topic in General
    I once had a 88 Accord that had a bad (seized) compressos which made an awful noise when u turned on the AC. The belt would start to burn fast cos (engine) pulley was turing while the compressor was stuck. Good luck with it...
  2. dhp replied to GTAm's topic in General
    sorry; my bad.. OE - Original Equipment / OD - Outer Diameter of the tire. Its ok to increase the wheel size for looks but you will have to re-callibrate the gears on ur speedometer if you increase the OD too much. Another issue is clearence, the tires could start rubbing against the fenders (unless ur willing to roll back the fenders). another issue is with bigger wheels u often increase the rotating mass (unless they're super light weight alloys). so, when u hit the brakes u have to stop the innertia of the entire car plus the additional rotating mass u just added on. IMHO biggest issue is the torque loss: torque by defn. decreases the further away u go from the rotating axis (remember "goornaya" - O/L science). So if u add 2inches to a 20 inch tire u just increased ur distace by 10% hence the decrease in ur torque put down to the road. Which means a HUGE diff if ur into getting off the line fast. But when u hit high speeds, ur car travels farther per revolution, so u save gas...its a choice u make depending on ur driving style ok, I'll get off the soap box now...fyi;just so u know all the facts, I went from 15-17" wheels so I dont have much right to speak. Also, bigger wheels only show off ur tiny brakes. Its ur car, ur choice on how big u wanna go..
  3. dhp replied to GTAm's topic in General
    if ur trying to figure out OD or stay close to OE OD for speedometeer accuracy and clearance, try this calculator remember the bigger the OD, the harder it is to get off the line, ur wasting ur torque but it gives better gas mileage @ high speeds
  4. also, if the cooling sys is working correctly, You shouldnt have to add water/coolant more than once in a few months. However if the liquid is running hotter than spec and boiling inside it can eat teh rubber seals hoses etc. causing liquid leakage. IMHO : If you're losing a lotta liquid u might wanna fix teh cause instead of the symptom on a side note, if u have a radiator leak dont use any of the stop-leak stuff (US/UK) it will clogg your thermostat causing it to not open when engine temp goes up and eventually causing the water pump to go bad.
  5. OK motor heads, Here's why u use coolant: Under regular pressure (sea level) water is liquid from 0C-100C (remember O/L science?). When you mix (alcohol, salt etc.) with water, you can change the temp range where it remains a liquid remember A/L chem?). ie. You can raise the boiling point of the liquid (which is really good at hot temps in SL) and lower the temp at which it freezes. There are many variations of coolant/antifreeze depending on the temperature the engine is running in. While the cooling factor is important in places like the middle east the anti freeze is the big issue in N America and Canada. While rust prevention is just a slight side effect of using engine coolant the real reason is to keep the liquid from turing into steam. And usually its mixed with water at 50/50 ratio unless specified by manufacturer or comes pre-mixed. Coolant system needs to be flushed as recomended by car mfg (usually 30K miles), going by the color is not a good indicator cos the coloring is added on for indication and enviromental reasons. just FYI; don't swallow coolant - it often contains Methyl (or Ethyl) alc - remember the same kinda stuff that makes ppl go blind when kasippu is distilled improperly. There are restrictions on disposing coolant in most countries, not sure what to do in SL - IMHO pour it onto hot concrete or road so its evaporated.
  6. dhp replied to Pericles's topic in NISSAN
    nice looking 180sx..4 lug version proly means no, LSD dont know much about the 180sx but the 240sx is a damn good car esp if it has the (sylvia) SR20 engine or atleast has the LSD ( 5 lug wheels). The SR20 is a popular mod in the US and even some with the RB20/2.5 and even VQ30 mods. Good cars to get sideways in....D1 style
  7. from what I remember seeing on "Car Crazy" an early 1900s Rolls Royce Silver Ghost is the most expensive car (40mil US-insured value) in the world. pic I think the the bugatti Veyron is the most expensive current production car (1.3mil US). The Veyron is the best car that I'll never own - I am a lil biased towards the veyron
  8. dead on DON..The 1st feeds the computer with info to adjust air/fuel mixture while the post CAT sensor if often a single stage sensor which tells you if the CAT goes bad (which happens if u use leaded gasoline) like I said b4 I have been running with a bad O2 sensor (exhaust manifold) on my maxima since Dec 03. I may have suffered a lil bit of economy due to bad fuel mixture. But I loose waste more fuel due to my heavy right foot and ofcourse on nissans we have to worry about the KS (knock sensor) and all then the ghost codes with missfires.
  9. well, atleast u got it fixed U could've driven around for a lil while if you had to. Ur emissions and consumption may have suffered a lil.. howmany O2 sensors does that model have?
  10. dhp replied to Pericles's topic in BMW
    WOW thats more torque than I expected. thats similar to 3.0 na engine...lots go-go in slow-mo and at such a low rpm...awsome. Enjoy!
  11. dhp replied to Pericles's topic in BMW
    nice ride max... it hurts to hear howmuch it cost you, thats E60 money...wow! just wondering if the 2.0 d is forced or na (nice torque if turbo) reason I am asking is I've seen some tds without the "t" INSP II sounds damn cheap in SL, I pay 400 bones here (2.8 E39 2K). BUt I am driving like a grown up so it only comes like every 15K miles. I get an oil change inbetween (2 lights left) just FYI: keep an eye on the damn fan motot bearing, if it starts to wobble, REPLACE aas its knows to come loose and tear everything up. I've seen one that even dented the hood (bonet). Also go with BMW antifreeze and get the BMW leater kit (dont use cheap stuff as it will dry and crack the leater) good luck
  12. put a 90 degree drain tube (like the ones u get in the bumper lights). DONT try to seal the unit unless u can guarantee that water wont get in (other wise water vapor has no where to go once it gets in). If you really wanna seal it, put it an oven get it hot (close to 100C) then when your sure all the water is out seal it with silicone. (be careful not to get it too hot-I've melted a few making clear lights). IMHO, put a drain tube and let it breathe, the air inside needs to expand anyway... btw, are you talking about HIDs or just hallogens?
  13. Thusha beat me to it. Try the manual "paper clip diagnostics" and see what it is. It should be a 2 position brown connector with green wires - underneath the passenger side carpet (mine is a US spec Vigor - so no flaming if wrong). Try Honda forums once u get the number...good luck Most proly its an O2 sensor - not sure howmany ur model has (my Nissan has had 2 bad ones for about 2.5 yrs) but get it fixed! do as I say not as I do
  14. good article, only thing is most CVTs are still going thru infant product cycle. Maybe the next gens will be better. I have read that the new Nissan muranos epuiped with CVT changes ratios when u least expecet robbing HPs from that wonderful 3.5 engine. It also sucks that they dont ofer this model in a manual (6spd). Which is why the CX7 is rated better than the murano. As with all new technology, It will take a few gens to figure out the lil kinks.
  15. here are the photos http://harisphotos.photos.gb.net/c970522.html
  16. Hey guys I was at the May 11th practice at the Indianapolis Motor Speedway. It was a cold rainy day and there was a good chance that practice would be cancelled, but I hung around for about 4 hours until they dried the track. You can see the JET dryer on the video clip. They finally rolled the cars out around 1:45 pm and the wait was worth it. I was grinning from ear to ear being that this was my first time being so close to a car going at 215mph+. This was also Ethanol day…I was told that this year’s field will all be using some mixture of ethanol (75-85). The ultimate goal will be to run entirely on ethanol… it would just mean a whole lot more pit stops as you get less mileage per gallon, but its cheap and has less harmful emissions. US energy secretary got to rid in a 2-seater car. I would pay big bucks to go for a ride-along at 220mph The sights, the sounds and of course the smell was awesome. If any of you guys will be in the area next year, I highly recommend the practice days. You get more access that you can even dream of at an actual race day. The general public admission is only 5 bucks. I also have a lot of respect for those photographers who are able to snap quality pics of a car doing over 200mph. I will post my amateur photos soon J here is a lil
  17. wonder how the M15s will come to the US. The M12s were brought to US (by 1G Racing I think) as a Kit car, as it wouldn't pass the emissions and/or crashtest requirements. M12s came to US in 2 crates, one with car and the other with powertrain. 1G puts it together in about 40hrs or so...its still hard to imagine someone spending 135K U$ for a car that's registered as a homebuilt kit car...insc has to be a hassle
  18. ;I saw it...W12 is a sweet engine...W16 is even better
  19. I dont really mind them keeping the invasive (obstructive) gadgets on the 7 series, but the 3 series should give more control to drivers. BMW didn't even offer a manual shift 7 series version in the US for the (94-02)...and they have the nerve to use a stick shift on the movie Transporter.
  20. Definetely the 5 series. bimmers have have always had a lil bit more sportier suspension and steering response than their Merc counterparts (esp with the M-sport pkg). That is until the recent versions started adding the damn idrive and all other gadgets that take away control from the driver. New bimmers (esp 3 series) Makes a good car for ppl who cant DRIVE. BMW should make more cars for enthusiasts and not for yuppies who wanna get a 3series as a family sedan to fit their 2 child seats. Anymore, you have to get an M3 to get a bimmer that will let YOU DRIVE. Afterall the yuppies who cant drive can always get the Cclass I know I am off topic with the 3 series remarks, but it gripes my A$$ with what BMW is doing. The reason bimmers are held with such high regard is because they were performance cars that were also safe daily drivers. Then somewhere down the road they became more luxury and less performance...despite their record sales, they have been deviating from the formula that had worked for them for decades.....I just hope they will start offering more affordable decent performance models that arent all driven by the silicon brain. I'd trade the bluetooth and navigation for instant throttle response....I'd wanna car that goes when I tell it to (w/o hitting the kick down), instead of thinking about it.. afterall, its suppose to be the ULTIMATE DRIVING MACHINE...not the ULTIMATE MACHINE THAT DRIVES YOU AROUND
  21. Make: Honda Model: Accord hatchback Year: 1988 Price: 1000 USD from auction this was the first car I bought with my own money....used it for 4yrs and 50,000miles until one redneck SOB (didnt have a CDL or DL) lost control of a dump truck and crashed into me...totalled my car and broke some bones. pic>> It was sad cos I painted the whole car and did all repairs myself... I try not to get too attached to a car since then In SL, I used a Daihatsu Charade, late 80's model, 998cc, 3cyl diesel,Red/blk [3450] I have no idea about the hp. 0-60: eventually. One time , I had 8 guys in the car(all the seats except driver's were out for upholstery wrk) doing 80Kmph down parlieament rd....those days are gone forever so many ppl had many life changing experiences in this car
  22. wow! thats a pc of history (blessed by Mr. Z himself)... I worked with this guy who had a 71 he did all the body work done and primered the entire car & then put racing stripes on the primer until he had enough money to paint it. It still looked good
  23. dhp replied to fuzzo's topic in General Automotive
    so then Nissan is calling the 4door a Skyline as well? and yes, the G35 and 350Z share the same engine in US there are Z air intakes on ebay as a performance mod for the G35, and Injen air intakes for 350Z
  24. I've seen pics of some G35 versions with the VK in em, at first these were called "skyline spy shots"
  25. I didn't think there were that many. thats pretty cool though 2 of my friends sold their 350Zs cos they feel it doesnt have enough power. There seems to be plenty of them lined up at the dealerships. I guess with most companies coming up with 275+hp cars that weigh close to the Z, it can easily get smoked...also the camber/suspension probs (03 and some 04 models) turned off ppl... few was returned as lemons and was going for cheap but can't get a bank loan for a lemon its still a pretty good track car...wonder why Nissan hasn't released a turbo version yet...maybe they're waiting for the new Supra they need to offer a 350hp+ Z...turbo it or drop a V8
