Everything posted by Mean Green z28
Direct Power Supply To The Radiator Fan.
When I used to drag race more often, I installed a little wiring harness/switch (got it from a friend who bought it off some vendor) that piggy-backed on the fan wiring harness. What it would do is let me turn on the fans while the car was turned off and cooling down in the pit lanes. It would also let me turn on one or both of the fans even if the temp wasn't high enough to turn the fans on (by the PCM). If the switch was turned off, it'll work just like the factory wanted using the temp switch. Those fan motors are pretty simple/rugged and rarely burn out, so it isn't such a bad thing.
Intercooler Mystery Apparatus
to add to my previous comment after doing a bit more digging ... on a n/a car (not boosted) the box/tube you usually see (also called a resonator, much like what a muffler does) is there to quiet down the sound of the intake air flowing through the main tubing, and on a boosted car, it's probably there to prevent compressor surge. On the new Mustang, the car was so quiet on the inside, they actually ran the tube to the firewall so it feeds the driver with some sound to at least "feel" like the car has power (not that it doesn't, but we all lover the "sound" right?). Example ... in the pic below of a engine bay, look at the tube running from the from to the intake manifold and you'll see a huge box sticking to both sides of the tubing. ... hold up, looking for it it's the first pic on this post... http://www.supraforums.com/forum/showpost....mp;postcount=28
Hard Braking
oooo, I wanna touch!!!
Rx8 Club Cruise
Cool stuff dude. You guys should drive south and join us for our Cheese steak Run to Philly. We started this a while ago while in college (and only a couple of hungry college buddies craving cheese steaks at 3am) and now has expanded to a few MD car clubs (although people from other states meet up and drive too) and is getting quite popular and although the main characters who started it aren't that active, the clubs are keeping it going so it's all goooood ... it's on FB but I can't post the link up here 'cos the site keeps garbling it up; but if you're interested, hit me up on FB (tburah1 at gmail dot com). Hopefully my car will be ready by then, but I'm sure to just ride along with a buddy if not
maybe it's there to act like a blowoff valve but not exactly? If there's air passing by the port that leads to that pipe, it'll create a vacuum in the pipe. When you let go of the throttle and the throttle blade closes, the surge of air has nowhere to go but slam against the throttle blade; therefore the canister takes some of that shock by letting some of that pressure relieve itself within the pipe ... Actually, this makes more sense in a natuarally aspirated setup than a turbo setup ... errr, am I talking baloney here! Either that or it's there as a muffler to reduce the sound of the air charge like in most N/A cars. I'll check with some other friends to see if they know ... what's kinda vehicle is this???
Pagani
my pants just got a little tighter in the crotchular region ... lol
Transformers 2-megatron's New Ride
MEGAN FOX IS A MAN !!! http://weeklyworldnews.com/2009/01/14/megan-fox-is-a-man/ LOL
Snow Rallycross
Damn, that looks fun as shyt!!!
Biking Day Out
I think the HP figure was around 200. Did a search and what I found was rated @ 187; and 197 with the ram air effect at speed ... http://www.motorcycle.com/manufacturer/kaw...tion-15797.html ... I believe every bit of it! lol ... my boss's bike went 9.90's in the 1/4mile at the local drag strip straight out the factory with only a lowering kit to make it launch easier without lifting ... some websites out there say they've been 9.78! ... http://www.motorcycle-usa.com/157/299/Moto...strip-Test.aspx ... DEF. FASTER than the Busa ... well a buddy of mine had a modified turbo Busa that was in the high low 8's so not THAT fast ... lol
Biking Day Out
NICE! I've ridden the Kawi ZX14 up and down the street (my ex-boss has one) and the damn thing quite simply scares the shyt out of me ... lol I used to have an older ZX600 for a couple months that I bought in pieces 'cos it had been in a wreck. Put it together but never got it completed enough to get it on the road, but I did have fun riding it up/down the street and fooling around with some other friends and their bikes. Traded it for 2 full sets of wheels/tires ... lol
Vibration While Braking At High Speed
Warping usually happens when the disks heat up a lot more than they're usually expected to handle, and also when they're near their end of life; 'cos the disk is worn out so much that it cant handle the heat build up. Basically think of it like a potato chip. It may be nice and flat and measure the same, but is wavy and therefore makes the car shudder when you apply the brakes. Like Elvis said, it needs to be put on a lathe and checked; if the thickness of the disk is under the min. spec after they are cut (an experienced machinist could tell you that by measuring the high/low areas before they are cut), they're no good, 'cos they'll warp really quick even after a few hard stops.
your disks are warped. If they're still within spec. (minimum thickness hasn't been reached) you can get them cut at a machine/brake shop, or you need to replace them.
Mercedes Benz Unimog
I've always had a "thing" for them, badass trucks with no excuses
Subaru Convirsion
depends ... contact someone who does the conversion. I know of people who do it, but I'm not sure if they are sponsors here and so I can't just mention names. They're pretty popular in the automotive world in SL, so I'm sure it's not gonna be hard tracking them down. First get a price from them, then lay out your plan. What will you spend/save along each path? Can you afford a STI model right now? If so, go for it. You'll save yourself the hassle of doing the conversion + you wont have to spend on getting the STI body kit/etc.. If you would rather not spend so much all at once, then it's clear what you need to do. I'm speaking from experience, so not everyone will agree with me. I'd rather save up and buy the car I really want in the end too, but sometimes good deals come up and you just can't let it go just because one small feature isn't what you want. Ofcourse, I do all my own work so swapping/converting is only about buying the parts, working a couple late nights and selling the parts that I took out to recoup some of the cost.
Importing Dslr Camera Lenses (any Idea What The Tax/duty Etc Costs?)
Cool! BTW the dude named "tburah1" posting comments about your pics is me ... lol ... haven't uploaded anything to flickr but my pics are on picasaweb.com/tburah1
A Vibration When Nearing 100kmph
just to add some humor, STOP DRIVING SO FAST and it'll all be okay
Presidential Inauguration
Well, I noticed that a majority of Sri Lankans were very interested in and supported Obama so here's a link to those of you who would like to follow the ceremony ... it's live and should be active only today ... http://www.hulu.com/live/inauguration
Ducati V-one - Twin To Supercharged Single Conversion
Story... http://thekneeslider.com/archives/2009/01/...gle-conversion/
Congratulations Ripper…
Congrats dude, hope everything went smooth (no pun intended, lol) and your wife and the kid are doing good and in good health.
I'm BACK! lol Ripper, glad to see you're enjoying your camera ... it's an awesome piece dude AND CONGRATS ON BEING A DADDY!!! TAKE PICS OF THE KID!!!
V8 Lancer
NOW THAT'S AWESOME!!! Although that looks like a turbo to me ... that things gotta be a beast!
Long Beach Motorcycle Show
If Darth Vader rode a bike, it'd be this one ... and if I had money, it' be me in a Darth Vader suit *NOTE TO SELF* - Need to buy a bike ASAP
The New Benz Breauty
damn, I'd hate to get even a slight dent on that car, it'll show really well ...lol
First Tuneup @ Agents
exactly. There's nothing to be gained by reflashing a computer cos it'll be the same tune. The only thing you can do is make sure all your sensors and plugs/filters/oil/etc are in good condition and you'll be good to go with some good driving habits.
8sec. Street Car ... Now This Is What It's All About!!!
Car belongs to David, known as MightyMouse on the forums ... His first one crashed at the track, so he took most of what he can out of it and built this with a few more tweaks ... car is a true street car and this run was made on the very same 17" wheels/tires he drove to the track with No drag wheels, tunes, etc. just drive up and GO! http://upload.streetfire.net/video/8-secon...s-MM_201441.htm
