Everything posted by Mean Green z28
Micro Double Decker
This is awesome that SL is moving up (atleast vertically in buses) ... hopefully, low lying tree branches will be trimmed before this bus goes on any out of town escapades. I'd hate to see that huge front glass shattered in its maiden voyage. So the first bus was donated to the president? What's he gonna do with it? Drive it around town?
Rain Water On Vehicles
A "good" car cover is multi-layered with a nice soft inside (to protect the paint from scratching on the fabric), an outer layer that keeps water out and is UV resistant and the whole thing has to be able to breath so it wont bake the car under it and let any condensation evaporate. Also, before you put the cover on, you need to make sure the car is clean and free of anything that'll scratch the paint when the cover is put on and taken off.
Colombo-fort New Colour-light System!
Holy shit, lol!
Wish I Was A Kid Again...
I don't think a kid would have enough patience to sit and do that. That's some extremely detailed work, CRAZY!
First Ever Non-stop Motorcycle Ride Across Usa
PLUS, he never even stopped for a bathroom break! Lol, diapers?
http://www.ridermagazine.com/output.cfm?id=1685863
Mercedes Benz Slc Gullwing
Nice ... I'll never be able to afford it but, NICE!
Changing The Gearbox From Auto To Manual
That is what i was trying to explain in my post above too but I think my post was misunderstood. There's a LOT to be taken into consideration including the the PCM 'cos the auto/manual programs are different. The manual program holds the rpm's a bit longer during shifts so the rpm's dont drop rapidly while the clutch is down and the guy is shifting while the auto trans. program doesnt' have that feature ('cos there's no disengagement in the torque convertor during shifts) but has all the shift tables and line pressure blah blah blah info. Atleast that's the way it is on the f-bodies. There's wiring, clutch safety switches for startup/cruise control, pedals, etc. too. If done correctly, it's possible ... if you're not ready to do it right and do it all the way, don't even shake a stick at it! For example, A simple rundown of my swap from Auto to manual on first my Camaro and just recently on my TransAm is as follows. I may have forgotten some but I've tried to show how involved it is. There's a LOT of measuring, cutting, lining up, assemble, remove, reassemble .. then do it all again... argh! Had to cut a hole in the floor where the shifter comes through. Needed the boot and console lid from a manual car. Had to remove the auto pedal assembly and install the manual pedal assembly. and that's a lot of fun 'cos the entire steering column needed to come out 'cos it wrapped around the top of the column. Had to cut a hole (and two small holes for bolts) in the firewall for the clutch master cylinder. Needed new clutch and flywheel assembly along with the new transmission Needed a new cross-member for the trans 'cos the manual trans is longer Although I didn't do it, the entire engine harness needs to be swapped to a manual harness and even the interior harness needs to be changed if you're going all the way (auto shifter has a multi-selection switch for park/neutral/reverse/gear indications to the PCM/starting system. I creatively (also read, digged into my SL roots ... lol) piggybacked off the harness and ran my own wires to the clutch pedal, reverse lights/cruise control/etc. so I didn't have to rip apart the interior and get everything off a junked car ... lotsa $'s!!! Had to reflash the PCM with a manual tune with different tables and with updated speedometer reference signals ('cos it works off a reluctor wheel not a cable). Had to remove all the cooler lines/etc. from the auto tranny to clean it all up. I just plugged the tubes for the cooler lines in the radiator, but if it was the other way, I've have needed a new radiator too with new cooler hard lines/etc. Thankfully, our cars dont have the shift indication on the dash, so I didn't have to swap that out either. Going manual is Lot easier than going auto. since the manual trans doesn't need as much electronics to run (just speedo, reverse switch, and shift lockout) What I did with piggy-back wiring can def. not be done and requires atleast the engine harness with the huge transmission connector with like 25 wires going to it. Thankfully, there's some companies that sell kits now with harness branches that can be pinned into the PCM/wiring harness so that you don't have to do the whole harness swap, but that too takes time and patience and it's easier to swap harnesses if you have one lying around. Most people going to auto setups usually aren't going for a stock setup anyways, so everything is custom and the trans is usually a manual shift valvebody setup so there's no computer control on them either, so it's just bolt up and go!
Cleaning Alloys
Media blasting and polishing or strip and paint?
I don't think that's true in most cases. If the swap is done correctly with the right parts, then it's a totally feasible project. I myself have done such conversions (auto>manual, Manual>auto) many times on mine and customers cars and have not had one issue arise from it. It takes a lot of knowledge about what you're doing and how it's going to affect the powertrain. Saying the gearbox would not work as original would mean that the installer didn't do a good job at it and just threw things together or the used transmission that was being installed was a piece of crap to begin with. I know from experience that some mechanics in SL take on jobs larger than their knowledge/abilities and the customer gets screwed in the end since they either didn't get the right part or just didn't know what they were doing. The only issue you may have on a modern car is that the auto transmissions are computer controlled in most cases, and therefore may require a wiring harness/computer that matches the relevant transmission being installed (usually only if you're going from manual to auto).
Mud-grrrrrrr
You're having too much fun!
Finally It's Out
And what's the dealer markup?
2010 Chevrolet Camaro Revieled !!!
Yeah, that's crazy that the Cobalt SS is so damn fast. It's a light car and handles really well for what it is and the power it has. Fastest FWD on the track ... crazy! EVO IX = 8:11 ... NICE! ... Here's most of the other numbers, those seem to be just a few handpicked numbers ... http://www.supercars.net/PitLane?viewThrea...0&tID=10073 ... More info on the 5th Gen. Camaro Vids ... http://www.chevrolet.com/camaro/multimedia/ ... I love the ambient lighting on the dash.
Look at those "performance" cars below the Camaro .. suddenly, the 8:20 time doesn't seem too shabby ... just goes to show how blisteringly fast the Nissan GT-R and the Corvette ZR1 are .. it's crazy!!!!
lol Also, just found the results from the Camaro out at the Nurburgring NurburBring It On: 2010 Camaro Cuts a Hot Lap Date posted: 07-22-2008 DETROIT — You can't launch a car with any aspirations of "performance" and not do your time at Germany's famed Nürburgring racetrack — it's just plain expected these days. So General Motors Corp. certainly wasn't about to shy away from the 'Ring with the sizzling new 2010 Chevrolet Camaro. At Monday's official unveiling of the production version of the new-age Camaro, Inside Line chased down a ranking Camaro engineer and asked for the crucial lap time. Doug Houlihan, GM's chief engineer for global rear-wheel-drive vehicles (the architecture underneath the Camaro, the Pontiac G8 and all that blowsy, big-V8 Holden stuff from Australia, where the platform originates), coughed it right up: A Camaro SS ran the Nürburgring in 8:20. A quick scan of an authoritative listing (it definitely looks authoritative, anyway) of Nürburgring lap times at supercars.net shows cars posting a lap time of 8:20 include the E36-generation BMW M3 in 1999, the Porsche 911 GT3 (993 generation) in the same year driven by 'Ring ace Walter Roehrl and stuff like the Audi RS6 in 2001. For a little extra perspective on that 8:20 lap time, GM recently boasted the coming '09 Corvette ZR1 did it in 7:26.4. "We learned a few things," from the 'Ring session, says Houlihan, which led the Camaro development team to tire supplier Pirelli for some subtle changes that he says fine-tuned steering response and turn-in, and also resulted in some nitty-gritty tweaks for suspension settings — all of which will further improve the Camaro's on-road handling. Houlihan also said all Camaros — V8 or V6 — will feature the best StabiliTrak stability control system GM can offer; the SS enjoys essentially the software from the Corvette's magnificent Active Handling system that we insist remains the world standard in performance-oriented stability control. The Camaro SS stability control will have a track mode, a performance mode and a setting that fully disables stability and traction control. Stability/traction control for all Camaros can be fully disabled, but Camaro SSs with the six-speed manual also get a launch control feature. Houlihan also said the 2010 Camaro's coefficient of drag is an OK, but unremarkable 0.35 for the SS and 0.36 for the LS/LT V6 models. Ed Welburn, GM's vice president of global design, said it's tough to get super-slippery aero numbers for cars with full-width grilles and recessed headlights — design cues Welburn and his styling team insisted on, obviously, to deliver on the 2010 Camaro's retro promise. We whined the RS appearance package that adds high-intensity discharge, "halo ring" headlamps, unique tail lamps, a rear spoiler and 20-inch wheels makes it almost impossible to distinguish a V8-packing Camaro from a V6 job. But for those of you who can spot the difference of an inch, Houlihan says there's one giveaway: the exhaust tips for the Camaro SS, which is V8 only, are 96mm (3.7 inches) in diameter. But LT Camaros (standard 3.6-liter V6) — even with the RS package — have exhaust tips that are just 3 inches in diameter. What this means to you: The Nürburgring number proves even if it's a little heavy, a Camaro SS can run with some pretty exclusive company. And with 300 horsepower, the Camaro V6 doesn't exactly earn the "secretary car" stereotype, either. — Bill Visnic, Senior Editor, Edmunds AutoObserver
Corvette Z06 ... http://www.edmunds.com/new/2008/chevrolet/...0463/specs.html ... $71K Base Number of Cylinders: 8 Base Engine Size: 7 liters Base Engine Type: V8 Horsepower: 505 hp Max Horsepower: 6300 rpm Torque: 470 ft-lbs. Max Torque: 4800 rpm Drive Type: RWD Fuel Tank Capacity: 18 gal. EPA Mileage Estimates: (City/Highway) Manual: 15 mpg / 24 mpg Range in Miles: (City/Highway) Manual: 270 mi. / 432 mi. MB C63 AMG ... http://www.edmunds.com/new/2008/mercedesbe...5865/specs.html ... $53 Base Number of Cylinders: 8 Base Engine Size: 6.2 liters Base Engine Type: V8 Horsepower: 451 hp Max Horsepower: 6800 rpm Torque: 443 ft-lbs. Max Torque: 5000 rpm Drive Type: RWD Fuel Tank Capacity: 17.4 gal. EPA Mileage Estimates: (City/Highway) Automatic: : 12 mpg / 19 mpg Range in Miles: (City/Highway) Automatic: 208.8 mi. / 330.6 mi. MB E63 AMG ... http://www.edmunds.com/new/2008/mercedesbe...1595/specs.html ... $85 Base Number of Cylinders: 8 Base Engine Size: 6.2 liters Base Engine Type: V8 Horsepower: 507 hp Max Horsepower: 6800 rpm Torque: 465 ft-lbs. Max Torque: 5200 rpm Drive Type: RWD Fuel Tank Capacity: 21.1 gal. EPA Mileage Estimates: (City/Highway) Automatic: : 12 mpg / 19 mpg Range in Miles: (City/Highway) Automatic: 253.2 mi. / 400.9 mi. I think those figures themselves show how misunderstood the LS* platform really is. More/equal power at lower RPM's and better fuel economy ... Also, that is the LS7 (the most powerful engine out there by GM ... save the soon to be released supercharged engine in the ZR1) in the Corvette, not the lowly LS3 in the next gen. Camaro, that's getting those mileage figures. Even Honda (you know how they love spinning the high RPMs) realized they didn't need to wring their S2K so high in the RPM range and redesigned the engine with slightly higher capacity and lower max RPMs. Yes, high revving engines are cool and shyt, but not necessary and it gets boring after a while 'cos you have to be in the upper ranges all the time to get any sort of performance from it. Take it to the Nurburgring and the Vette is also faster around it than both those MB's ... I see a winner here. Okay, those are family cars, what about a sports car ... what about the SL65AMG? Same story ... Costs $185 (over twice the Corvette) and still can barely match/beat the Vette at everything but it's weight (and that's a bad thing), and it's a twin turbo V12 ... geeez! ... the Vette. also come with a 100,000mile/5year warranty while the best on a MB is 50,000/4yr. Example on mileage: My friend's stock 2002 V6 Audi A4 gets about 18MPG on the highway while LS* cars with cams and headers/etc. with a good tune are getting somewhere in the 25MPG range on the highway regularly ... what gives? Sophisticated or too complicated? Everytime something goes wrong, it's a huge bill 'cos some electronic circuit went bad or one of those million sensors is acting up (always seems to be the case with European cars). Ofcourse, the interior in the Audi makes it all feel better 'cos its comfy and solid feeling ... atleast your wallet's gonna be much thinner, so it's not gonna be uncomfortable sitting on it on long drives.
First off, those engines are capable of quite a bit more power with a few simple bolt-on's and much more with a simple cam swap or heads. GM is not gonna encroach on Corvette territory with giving more stock HP to the Camaro. Those numbers are more than enough for the general public and it's easier to get the car through US emissions/sound requirements with de-tuning the engine to those numbers. Also, although we're die hard muscle car fans, we're not the one's keeping the car alive, we are dwarfed by the amount of cars the 'general' public would buy compared to us ... so the car is mostly marketed to them ... and they'll let us mod. the car to suit us. Such is the world... Also, talking about power levels compared to the Europeans ... the simple pushrod design is ancient technology for sure, but it's simple enough that it's giving the others around the world a good run for their money with the amount of refinement and power it's gotten through the years. For example, an LS7 Corvette crate motor can be had for like $15-17K putting out like 500HP ... the comparable MB engine with that level (or a tiny bit higher) of HP is close to $35-40K as a crate engine ... the LS7 spins to about 6500-7000rpm while the MB engine spins to like 8000rpm or something crazy like that. Also, when you buy a MB with that engine vs. a car with a LS* engine, the fuel difference in consumption is much better in the LS* car ... sorry, high tech is fun, but simple raw power will rule anyday. There's a reason why a majority of aftermarket engine swaps are to the LS* powertrain (ever heard of a Ford modular in a EVO? ... someone did put a LS1 in a EVO!) and almost all offroad sandrails/buggies use LS1 derived engines for the few simple reasons that they make ridiculous HP with simple mods and they're cheap and simple and you don't have to stress them as much to get what you need.
Mazda 3 For A T.v Commercial..
Awesome work on that man, really impressive
Final Production spec car was released on Monday ... woohooo ... guess who's starting to seriously put money in the piggy bank? LINK TO GALLERY http://www.autoblog.com/2008/07/21/2010-ch...ils-and-images/ You've waited long enough, so let's dispense with the pleasantries and get right down to the hard facts. Three models - LS, LT, SS LS and LT come with 3.6L direct-inject V6 (300 hp/273 lb-ft) SS six-speed manual comes with 6.2L LS3 V8 (422 hp/408 lb-ft) SS six-speed automatic comes with new 6.2L L99 V8 (400 hp/395 ft-lb) and Active Fuel Management 3.6L DI V6 gets 26 mpg highway 6.2L V8 with automatic gets 23 mpg highway RS appearance package available on LT and SS (includes HID headlamps with integrated halo rings, spoiler, specific taillamps and 20-inch wheels) Front and rear independent suspension FE2 suspension for LS and LT, sportier FE3 for SS Four-wheel disc ABS standard, SS gets four-piston Brembo calipers SS model gets adjustable Competitive/Sport mode for stability control and Launch Control on manual models Available 18-,19- and 20-inch wheels You can read Chevy's full press release after the jump and browse the official, full-size image collection in the gallery below. Stay tuned for our post of live coverage from our team on the ground. PRESS RELEASE Chevrolet Unveils The 2010 Camaro - A Fun, Efficient Sports Car For The 21st Century All-new, world-class sports car Fuel-efficient, 3.6L direct-injected V-6 delivers an estimated 26 mpg on the highway Range of fuel-saving, six-speed transmissions standard on all models and powertrains Powerful SS models equipped with LS3 V-8 (manual transmission) and L99 with Active Fuel Management (automatic transmission) Advanced vehicle technology, including Bluetooth connectivity and available HID headlamps with integrated halo rings Designed, engineered and built with GM's global development process DETROIT –Chevrolet introduced the production 2010 Camaro today. It is a heritage-inspired sports car for the 21 st century, combining great looks and performance; advanced technology and surprising efficiency – including 26-mpg estimated highway fuel economy. Sales begin in the first quarter of 2009. Built on GM's new, global rear-wheel-drive architecture, the Camaro is offered in V-6-powered LS and LT models, as well as the V-8-powered SS. All models and powertrain combinations include fuel-saving six-speed transmissions. "Camaro delivers all of the things that make Chevrolet such a revered, global brand," said Ed Peper, GM North America vice president, Chevrolet. "It competes with the world's best sports cars and does so with styling, fuel economy and value our competitors simply can't match." Advanced powertrain technologies, including engines with direct injection and Active Fuel Management, enable a satisfying balance of exhilarating performance and good fuel economy. "The new Chevrolet Camaro delivers a thoroughly modern, advanced package of performance, comfort and technology," said Peper. "It's a sports car for a new generation of enthusiasts that doesn't forget the heritage that helped make the original a cultural icon . That is no small feat and it took a worldwide commitment to achieve it." Indeed, the 2010 Camaro exemplifies GM's global development process. The design concept originated in the United States; engineering was directed by GM's global rear-wheel-drive team in Australia; validation was conducted on roads around the world and assembly will take place at GM's award-winning Oshawa facility in Canada. Product highlights include: Sleek styling with contemporary cues and 10 available exterior colors LS and LT models offered with an advanced, 3.6L direct-injected V-6 engine with variable valve timing and a choice of six-speed manual or automatic transmissions SS model offered with 6.2L V-8 – including fuel-saving Active Fuel Management on automatic-equipped combinations – and a six-speed manual transmission Four-wheel independent suspension system, including a 4.5-link rear suspension Variable-rate power steering with the rack mounted forward of the front axle for greater driver feel Four-wheel disc brake systems standard on all models, including four-piston Brembo calipers on SS models Stabilitrak stability control system and traction control standard on all models Competitive/Sport modes for the stability system offered on SS models, including launch control on SS models equipped with the six-speed manual transmission Family of 18-, 19- and 20-inch wheels Detailed interior with heritage-inspired design, excellent attention to detail and available ambient lighting via LED light pipe technology Robust body structure and exceptional build quality Six standard air bags, including head curtain side-impact air bags and front seat-mounted thorax side air bags RS appearance package available on LT and SS, including HID headlamps with integrated halo rings, spoiler, specific taillamps and 20-inch wheels The new Camaro also has technologies that enhance performance, comfort and convenience, including: Bluetooth phone connectivity Premium Boston Acoustics audio system USB connectivity Ultrasonic rear parking assist (late introduction) Remote vehicle starting system OnStar XM Satellite Radio Additionally, details such as frameless door windows with automatic indexing glass contribute to the overall feeling of quality, substance and technical prowess. Design details With a design that is very faithful to the original concept, the 2010 Camaro is a 21 st century sports car that acknowledges its heritage. A long front dash-to-axle and short rear deck give the Camaro classic proportions, while a sleek windshield profile, wheels pushed to the corners and muscular fender forms are modern elements that reinforce its advanced engineering – and give the car a decidedly aggressive stance. Elements such as a forward-V shape at the front of the car and "gills" in the rear quarter panels are distinctly Camaro cues, as are the broad rear fender "shoulders." Those elements make the new Camaro instantly recognizable, but their execution is smoothly integrated into the contemporary exterior form. A family of large, 18-, 19- and 20-inch wheels also contributes to the Camaro's modern appearance. "The new Camaro is just that – new," said Ed Welburn, vice president of GM Global Design. "We acknowledge the nameplate's strong heritage in the design, but recognize that keeping this modern sports car relevant meant more than simply honoring a classic car. The line forms, stance and overall execution are consistent with other new Chevrolets." A well-executed balance of heritage, modern design and attention to detail also characterizes the Camaro's interior. A pair of deeply recessed instrument binnacles that feature round gauges in square housings is a nod to classic Camaros, while an available ambient light package offers advanced LED light pipe technology to give the cabin a distinctive and inviting glow. Cloth upholstery is standard; heated leather-appointed seats are available. Details such as large, chrome-trimmed controls, low-gloss surfaces and premium fabric or acrylic appliqués convey a richness that is unprecedented in previous Camaro models – and challenge its contemporary competitors. More great detail is evidenced in the available center-console gauge cluster, which takes its cue from a similar option on 1969 Camaros. It displays oil temperature, oil pressure, state-of-battery and transmission fluid temperature, all highlighted with modern LED backlighting. Powertrains An advanced, efficient 3.6L direct-injected V-6 with variable valve timing is standard on LS and LT models. Direct injection technology helps the engine deliver more power through increased efficiency, while maintaining fuel economy and lowering emissions. That means less fuel is consumed and lower emissions generated – including a 25-percent drop in cold-start hydrocarbon emissions. The Camaro's 3.6L engine also employs variable valve timing to optimize performance and fuel economy across the rpm range. It is rated at an estimated 300 horsepower (224 kW) and 273 lb.-ft. of torque (370 Nm). A six-speed manual transmission is standard with the 3.6L engine; a Hydra-Matic 6L50 electronically controlled six-speed automatic, with TAPshift control, is available. The high-performance Camaro SS is equipped with a powerful 6.2L V-8, with a choice of a six-speed manual or six-speed automatic transmission. Standard, manual transmission-equipped models receive the LS3 engine, estimated at 422 horsepower (315 kW) and 408 lb.-ft. of torque (553 Nm). The LS3 debuted on the 2008 Corvette and uses high-flow cylinder heads based on the Corvette Z06's LS7 engine to enable great low-end torque and high-rpm power. It is paired with a TR6060 six-speed transmission. A new, L99 V-8 engine is used on automatic transmission-equipped SS models. It is based on the LS3 and carries all of its high-performance design features, but also includes GM's fuel-saving Active Fuel Management feature. It enables the engine to run on only four cylinders during light-load driving conditions, such as highway cruising, to improve fuel economy. The V-8 is estimated at 400 horsepower (299 kW) and 395 lb.-ft. of torque (535 Nm); and it is matched with a Hydra-Matic 6L80 six-speed transmission. This combination delivers an estimated 23 mpg on the highway. Body structure and chassis The 2010 Camaro is built on GM's global rear-wheel-drive architecture, with a strong body structure that enhances safety, quietness and handling. World-class build quality and attention to detail are enabled by features including one-piece body side stampings and very precise tolerances between body panels. Front and rear independent suspensions are mounted to the rigid chassis, including a multi-link strut arrangement in the front with a direct-acting stabilizer bar and a double ball-joint configuration; and a unique, 4.5-link rear suspension that is double-isolated from the chassis for smoother, quieter driving experience. Camaro offers two suspensions. LS and LT models receive an FE2 (sport) suspension, while the SS receives the FE3 (performance) suspension, including a lower ride height. Each is tuned to match the performance capabilities of their respective powertrains, as are their wheel-and-tire combinations. A variable-rate rack-and-pinion power steering system mounts the rack forward of the front axle, for more direct action, an enhanced feeling of driver feedback and better weight balance. Brakes and chassis control Four-wheel disc brakes with ABS are standard on all models. LS and LT models receive single-piston calipers all around, with mass-reducing aluminum rear calipers. SS models have larger rotors that are acted upon by four-piston, aluminum Brembo calipers at all four corners. They are designed to stand up to the severe use encountered on road-race tracks, delivering excellent feedback and pedal feel, as well as fade-resistant performance during racing. GM's StabilTrak electronic stability control system is standard and incorporates traction control. The system on SS models includes Competitive/Sport mode that is adjustable for performance driving, such as on a racetrack; it also includes a Launch Control feature on SS models with the manual transmission. It enables quicker, more consistent takeoffs during performance driving. Safety Designed to protect occupants before, during and after a crash, the Camaro offers a comprehensive system of safety features – starting with a robust body structure and integral safety cage around the passenger compartment. High-strength steel and ultra high-strength steel are used in key areas throughout the structure. Safety technologies integrated in the Camaro include: Driver and front-passenger dual-stage air bags Driver and front-passenger seat-mounted thorax side-impact air bags Head curtain side-impact air bags for front and rear seat occupants Front seat safety belt load limiters and pre-tensioners The front passenger protection system senses children and small-stature adults and suppresses air bag deployment when appropriate. Standard OnStar service assists after a crash. With OnStar's Advanced Crash Response System, the vehicle automatically sends a signal to OnStar for assistance, even if the air bags don't deploy. Chevrolet is one of America's best-known and best-selling automotive brands. With the largest dealer network in the United States, Chevy is the leader in full-size trucks and the leader in sales of vehicles priced $35,000 and above. Chevrolet delivers more-than-expected value in every vehicle category, offering cars and trucks priced from $12,120 to $103,300. Chevy delivers expressive design, spirited performance and great value with standard features usually found only on more expensive vehicles. More information on Chevrolet can be found at www.chevrolet.com. Models: Chevrolet Camaro LS, LT and SS Body style / driveline: four-passenger, front-engine, rear-drive coupe Construction: unitized body frame, one- and two-sided galvanized steel EPA vehicle class: coupe Manufacturing location: Oshawa, Ontario, Canada Oshawa Car Assembly Plant -- The plant assembles the Chevrolet Camaro and Impala and Buick Allure. TheOshawa Car Assembly Plant has placed among the leaders in the J.D. Power Initial Quality Survey for the premium and mid-size segment for a number of years. Key competitors: Dodge Challenger, Ford Mustang, Nissan 350Z Engines 3.6L V-6 DI VVT (LLT) 6.2L V-8 (LS3, L99) Application: LS, LT SS Type: 3.6L V-6 6.2L V-8 Displacement (cu in / cc): 217 / 3564 376 / 6162 Bore & stroke (in / mm): 3.70 x 3.37 / 94 x 85.6 4.06 x 3.62 / 103.25 x 92 Block material: cast aluminum w/ cast-in-place iron bore liners cast aluminum w/ cast-in-place iron bore liners Cylinder head material: aluminum aluminum Valvetrain: dual overhead camshafts, four valves per cylinder, continuously variable valve timing valve-in-head; two valves per cylinder; roller lifters; Active Fuel Management (L99) Ignition system: electronic individual coil-on-plug; individual cylinder knock control and extended-life platinum-tipped spark plugs high-energy distributorless ignition; solid state direct-fire ignition w/ coil near plug and integrated ignition Fuel delivery: direct high-pressure fuel injection returnless, multi-port fuel injection Compression ratio: 11.3:1 10.7:1 Horsepower (hp / kW @ rpm): 300 / 224 @ 6400 rpm* 422 / 315 @ 5000 (LS3)* 400 / 299 @ 5000 (L99)* Torque (lb-ft / Nm @ rpm): 273 / 370 @ 5200 rpm* 408 / 553 @ 4500 (LS3)* 395 / 535 @ 4500 (L99)* Recommended fuel: regular unleaded premium recommended Maximum engine speed (rpm): 7000 6000 (L99) 6600 (LS3) Emissions controls: evaporative system, single close-coupled catalytic converter, equal-length exhaust, single underfloor catalytic converter, positive crankcase ventilation, intake and exhaust cam phasers, electronic throttle control evaporative system, close-coupled catalytic converters, positive crankcase ventilation, electronic throttle control Fuel economy (auto trans): 26 hwy (est) 23 hwy (est) Transmissions Hydra-Matic 6L50 six-speed automatic (LS, LT) w/ TAPshift Hydra-Matic 6L80 six-speed automatic (SS) w/ TAPshift Aisin Warner AY6 six-speed manual (LS, LT) TR6060 six-speed manual (SS) Gear ratios (:1): First: 4.07 4.03 4.48 3.01 Second: 2.37 2.36 2.58 2.07 Third: 1.55 1.53 1.63 1.43 Fourth: 1.16 1.15 1.19 1.00 Fifth: 0.85 0.85 1.00 0.84 Sixth: 0.67 0.67 0.75 0.57 Reverse: 3.06 3.06 3.67 3.28 Final drive ratio: 3.27 3.27 3.27 3.45 Chassis/Suspension Front: double-ball-joint, multi-link strut; direct-acting stabilizer bar; progressive-rate coil springs; fully adjustable camber, caster and toe Rear: 4.5-link independent; progressive-rate coil springs over shocks; stabilizer bar; fully adjustable camber and toe Steering type: variable-ratio rack-and-pinion Steering ratio: 16.1:1 Steering wheel turns, lock-to-lock: 2.5 Turning circle, curb-to-curb (ft / m): 37.7/11.5 Brakes Type: four-wheel disc w/ ABS; ventilated front and rear rotors; single-piston front calipers and single-piston alloy rear calipers (LS, LT); four-piston fixed Brembo aluminum front and rear calipers (SS) Rotor diameter, front (in / mm): LS, LT: 12.64 / 321 SS: 14 / 355 Rotor diameter, rear (in / mm): LS, LT: 12.4 / 315 SS: 14.4 / 365 Rotor thickness, front (in / mm): LS, LT: 1.18 / 30 SS: 1.26 / 32 Rotor thickness, rear (in / mm): LS, LT: 0.9 / 23 SS: 1.1 / 28 Wheels/Tires LS LT SS Wheel size and type: 18 x 7.5-inch steel 18 x 7.5-inch aluminum 19 x 8-inch aluminum 20 x 8-inch aluminum (front) 20 x 9-inch aluminum (rear) Tires: P245/55R18 all-season P245/55R18 all-season P245/50R19 all-season P245/45ZR20 summer (front) P275/40ZR20 summer (rear) Dimensions Exterior Wheelbase (in / mm): 112.3 / 2852 Overall length (in / mm): 190.4 / 4836 Overall width (in / mm): 75.5 / 1918 Overall height (in / mm): 54.2 / 1377 Track, front (in / mm): 63.7 / 1618 Track, rear (in / mm): 64.1 / 1628 (LS, LT) 63.7 / 1618 (SS) Curb weight (lb / kg): 3750 / 1705 – LT w/ automatic 3741 / 1700 – LT w/ manual 3769 / 1713 – LS w/ automatic 3780 / 1718 – LS w/ manual 3913 / 1779 – SS w/ automatic 3860 / 1755 – SS w/ manual Weight balance (% front / rear): 52 / 48 Interior Seating capacity (front / rear): 2 / 2 Headroom (in / mm): front: 37.4 / 950 rear: 35.3 / 897 Legroom (in / mm): front: 42.4 / 1077 rear: 29.9 / 757 Shoulder room (in / mm): front: 56.9 / 1444 rear: 42.5 / 1080 Capacities Cargo volume (cu ft / L): 11.3 / 320 Fuel tank (gal / L): 19 / 71.9 Engine oil (qt / L): 3.6L: 7.6 / 7.2 6.2L: 8.9 / 8.5 *Pending SAE certification. Note: Information shown is current at time of publication.
First Video Of My New (to Me) Car
Thanks. Yeah I need to get a new sig. Just have no good pics yet.
Some of you who have kept track/remember I bought a fixer-upper TransAm ... well, it's running! Drove it out of the Garage today to get to the passenger side of the car ('cos it was so close to the wall in the garage) to clean up some last bits and the wheels. Made the wife stand still (still as she can be, miss Shaky!) and take a vid. Still no proper exhaust, just open headers. Just painted the new 4" Mufflex exhaust system that's gonna go in with Semi-Gloss Black high temp paint, waiting for the y-pipe to come in. Sound is a bit crappy 'cos it echoed between my house and the neighbor's ... lol
Srilankan Talant 80km Per 1liter Of Water..?
Can't read a word of it 'cos the font is messed up. What it say? Did he get it to work?
Hid Kits
HID's, if used in regular housings designed for conventional bulbs, will scatter and not project ... thereby causing annoying glare for oncoming drivers. Yeah, they'll be bright, but that's about it. People have been grafting in HID projector housings from upmarket/optioned vehicles (BMW's/Infinity/etc.) and have done some pretty interesting mods. (I plan to in the future, but that's last on my list) ... either way, price and most def. quality/durability will drive the demand on mods such as this.
Modified Chery Qq
subtlety as in not do anything to it and yeah, it'll still be an ugly car. That thing looks like one of those modified 3-wheelers (although with 4 wheels this time).
Looking For "non-disposable" Air Filter Cleaning Kit
Just to add a bit more on maintenance ... if you have sensors in the intake between the filter and the throttle body (i.e. : MAF, IAT, etc.) it would be wise to clean them with some electrical circuit cleaner spray (like used on PC's or there's special spray cleaners for automotive sensors) while you're doing the filter 'cos the oil usually gets sucked in with the air and gets on the sensors and deteriorates the signals over time. Clean them often and take care not to break/damage them while doing so.
