Dodge Charger / Challenger
I think it's because the thread suddenly popped up on top in the discussions list this morning. I've seen it happen a few times. Probably because someone voted.
Countdown To The Upcoming 2012 Ferrari F70 Enzo Hybrid
The black car is a test mule, not a "speculative rendering" of anything. It's common for new unreleased designs to be obfuscated in such a manner as to make identifying the real design impossible. Google for spyshots of cars.
Hid Xenon Lights
Yeah, they always take a few seconds to warm up, even on cars which come with factory HIDs. If it takes over 10 seconds then you have an issue with the ballast.
Ever Heard Bio-Diesel?
I'd love to see your filtration setup, and also please do share the recipe for the catalytic process. Also have you sourced suppliers for the alcohol and the catalyst?
Diy Headlight Bulb Retainer
Wow I must have had my wires crossed when I did that post. The one the LEFT is what I made, not the one on the right. Thanks for pointing that out Davy.
- Post Whoring - Part 2
- Urgent - Starlet Price
I'm pretty sure other enterprising individuals have thought of this as well. There are simply too many blocking factors, the least of which will be your local MP when he gets wind of your business. Soon everyone will start wanting a cut out of it, and you'll eventually become Shell Gas 2.0. I'm just saying.
Actually E85 contains 85% Ethanol, not biodiesel. Cars which run on E85 have "Flexfuel" badges on them (I used to see them regularly during my time in the states). Both biodiesel and E85 are however biofuels.
Rudolf Diesel initially made the Diesel engine to run on vegetable oil. True story.
Rpm Limiter - In Toyota Vehicles?
The CV30 comes with a 2C-T engine. AFAIK they have no rev limiters. My Townace had a large adjustable bolt under the accelerator pedal which limited pedal travel, thus limiting the RPM.
Philips Bulbs
It came wrapped in bubble wrap, inside another box. I've never had any fragile items broken during shipment thus far.
Yes from ebay. I posted details here.
Autolanka Funniest Moments
It translates to "We may drive on the left but we are boys from the right/south". It's a play on words since dakuna is used to describe right (as opposed to left) as well as to describe south in the cardinal directions.
Where To Buy A Genuine Xbox 360Hdd
ftw.
These are Osram Nightbreaker Plus units, they're brighter than the regular Osram units my car came with. They reach farther and the light dispersion is better since the cutoff is clearly visible now.
So as I was swapping in the new Osrams that arrived today, my overeager self didn't notice the spring retention screw on one headlight was loose and the spring disappeared into oblivion when I undid the latch. So after freaking out for an hour pondering a few minutes, I improvised by using a key ring. The one on the right LEFT is what I made. It took me all of 15 minutes, and it works perfectly, if a little more pliable than the material the original spring was made of. On the right is what I made. All you need are two needle nose pliers. Edit: Due to an unexpected brain fart I was unable to tell my arse from my elbow when I made this post. Errors have been rectified.
Rev Limiter Question
Can you feel the rev limiter coming into play? If you have no trouble revving beyond 4k in drive, then it's probably nothing to worry about. It's probably a mechanism to limit damage to the transmission in case you shift into gear, since pressing the release button is not required for D <-> N.
Philips Bulbs
So the Osrams I ordered arrived today. Well the H4s arrived, not sure why the H3s didn't arrive with them since I ordered them from the same place. Here are some photos for comparison.
I used that method for a friend's Arcade version, the process is quite tiresome, hence why I didn't bother suggesting it to Ripper. We had to use a computer from the office to carry it out in the end because my desktop didn't go through the process properly and he has sexual relations with his Apple devices uses an MBP.
Yes I tried when the feature was first made available, but not since then. You can always purchase the official XB 360 flash drive, as recommended by Microsoft. Here's a link. http://www.ebay.com/itm/SanDisk-Cruzer-XBOX-360-16GB-16-gb-USB-Flash-Drive-usb-/120732733399?pt=UK_Computing_FlashDrives_SM&hash=item1c1c3b4fd7#ht_2594wt_1344
nuno, the USB stick does the same thing an HDD does, up to 16GB at least.
