terrabytetango
  1. On the Baseline some years ago. It was also up for sale on A/L but the adverts don't go that far back. It had red GT badges and appeared to be unmodified. Also remember the 111 code is also used for the 1.6 litre variants brought down by Toyota Lanka. I believe they were the GLi models, and can be identified by the 220km/h speedo plus leather seats.
  2. I wonder if they will feature the 6 wheeled Tyrell!!
  3. So recently I had the opportunity to remove the (non functional) front fog lights in my Vios and see what was up with them. The +(ve) lead on one of the bulbs (H3) had burnt through the insulation at the point where a joint was made to harness. I re-crimped a new connector, cleaned the lenses up with some brasso and made sure they were worked by hooking them up to a 12V 2.2AH Pb battery. However when testing them with the car, they refuse to light up and the voltage in the circuit drops to 0 upon hooking up either light. Power is available at both connectors. Now, I suspect its a shitty relay which is a result of the short circuit, however I'd like a second opinion as to what else might be wrong. Edit: Found the issue after tracing the wiring. There's an inline fuse holder close to the fog light relay, and cheap fuse in it had corroded blades, so I replaced it and voila, front fogs work now.
  4. It's a silver one, and it's real. 4AGE and everything, it was an auto.
  5. Thats would you would get if an Allion 260 and a current Axio had offspring.
  6. That TF gives me a chubby.
  7. No difference. My car doesn't even have an A/C button, the thermostat at the lowest setting is what switches off the compressor. However, do avoid starting the car with A/C on.
  8. Nothing from you in my inbox
  9. How much the bulbs set you back? I'm thinking of getting down some Osram Nightbreaker Plus bulbs (better light output than Silverstars apparently), but I would buy them from the agent in a heartbeat if the price was right.
  10. I've seen the silver one a few years back, it had a hideous set of wheels which were NOT anything Lotus would use; they were chrome and possibly had curved spokes similar to the "turbine" look. The image is stuck in my mind 'cos all I could think was HOW could someone do that to a Lotus.
  11. Monaco. You know you can't miss it. Saturday 18:30 - 19:30 / Sunday 17:30 - 19:30.
  12. Take a look at the Kia Rio as well while you're at it. Both are pretty solid cars. I too would suggest you set the bar at around 1.2-1.3mil.
  13. Use party streamer spray. They stick to the surface, and you can them in a bunch of colours. Cans are small though, but they harden and don't go flat/runny like shaving foam.
  14. Water in the exhaust pipe is fine, it happens when the exhaust pipe is cold, but yeah you do need a tune up ASAP.
  15. photos or it didn't happen.
  16. The new Alfa roadster is going to be based on a Miata. This is a good thing, really. http://www.wired.com...gle+Feedfetcher
  17. Sorry, by Delkanda strip I meant the stretch of road in Delkanda that contains all the vehicle spares shops. I'm unable to recommend anyone for electricals as its all DIY with me, but I'm sure the other members will be able to offer their assistance.
  18. Check along the Delkanda strip, they will have what you're looking for. And if you're just replacing it, it's a simple DIY job if you don't mind getting your hands dirty and like fiddling with your car (like 99.9% of the members here do). If you're fitting from new, you'll have to figure out switches and relays and stuff (the car will probably have provisions for fogs in the wiring harness already). I only speak from experience with my Vios but I'm sure its very much the same procedure with any car.
  19. I would advise against buying them. They are a huge distraction to the driver behind you, especially when they're in blue or white.
  20. I wish I could chime in but apparently no one plays these games on consoles? Edit: The PC is exclusively used for DOS Box and Guild Wars. Another edit: Any Minecraft players?? I so want to start playing but I'm afraid I might become addicted.
  21. +1 on the super diesel.
  22. I'd be very surprised if they don't, since they do have to provide service for 2C engines in the form of the shitty permit Corolla Diesels that have been trickling through since 2007.
  23. Why not get the tappets checked? I believe they require a periodic adjustment anyway due to regular wear and tear.
  24. DeLorean DMC-12
