- Motorque
Temperature Gauge
Well the overflow tank is generally useless for feeding water into the circuit when the system is under pressure. What usually happens is, any overflow caught by the tank is usually sucked back in (which I assume is what you're thinking of) when the temperature settles down, by way of the vacuum caused by the increasing density of the water. By the time all this happens, things will have cooled to a point where you can touch and open the radiator cap without hurting yourself. And by directly adding water to the radiator instead of the tank, you ensure there's no air pockets in the system, since if 5th grade physics serves me right air is an extremely good insulator and won't help in cooling down your engine. And as a practice, after I top it up, I start the engine and top it up again because the water level will almost always drop once the water pump starts doing its thing.
Lancer Service Manuals Available Here
I came across this post last year when I was still searching for a car, but since someone is apparently hoarding ALL the 1.5/1.6 liter CS and CK models (srsly, when was the last time you saw one for sale on A/L), I didn't have the opportunity to truly appreciate it
Auto News
You should read Asimov's "Sally".
Buyleasing
Its not the repayment as much as the trouble one might run into trying to obtain it that she's (and most loan applicants) worried about.
Land Cruiser 200 Or 2011 Montero Or Discovery 4 ??
VDJ200, like someone said earlier. Just saying 4.5 liter twin turbo diesel v8 is awesome. not to mention you call pull a house behind you. in 5th.
Under Compression Engines In Kia/ Hyundai Dieasel Models
Have either of you owned Korean vehicles? Stop talking out of your asses without backing up your claims. This kind of insular mindset is prevalent among the majority of car owners in this country because pissants like yourselves do nothing except expedite the perpetuation of retarded notions like those quoted above.
Buyleasing
I too have a personal loan from HSBC for 600K, installment comes at 14K and some change for 5 years fixed, no issues so far. Loan was approved July last year.
Autolanka New Site 2012
FTW! And maybe we will see Tapatalk integration?
Cool Ebay Gadgets For Cars
And here's my contribution to the thread. I came across this a few days ago, and I believe its the perfect alternative to the regular 12v outlet fm transmitter. http://www.ebay.com/itm/Car-Digital-CD-Changer-AUX-USB-SD-MP3-Music-Adapter-for-TOYOTA-Lexus-Scion-/270956435275?pt=LH_DefaultDomain_0&hash=item3f1643174b#ht_4996wt_1110
I'm sorry, but I must pull a Sheldon on this. The DMG-01 is fast reaching antique status, plus the one in the photo has a 3rd party powered speaker attachment which are pretty fkn rare these days. Here's my DMG-01 daily driver with a backlight mod.
- Fixing A After Market Cruise Control Kit
- Alfa Romeo
Autolanka Funniest Moments
It is indeed a fail. That sticker should be on a very small car with a very big carbureted engine with 8 cylinders in a V configuration.
Lane Change Indicator ?
The Toyota Vios comes with that feature. It doesn't have a timer though, it just continues operating as long as you hold it in either position. The tick tock sound (electronic simulation in my car's case) is muted at that position too. And before anyone says its just the play in the right hand stalk, the feature is documented in the user manual.
Greatest Automotive Nation?
I remember voting for Japan as well, simply because of everything it had to overcome to come after WW2, including the fact that they have next to no natural resources. Americans are not passionate about their cars, just look at their current line up. I drove nearly every American compact sedan made between 2007 and 2009, and they don't even come close to the build quality of their Japanese counterparts. Their main selling point is more bells and whistles for a lower price.
Noise From Drivers Side Wheel
My car makes that noise every morning (only audible to me when driving parallel to a parapet wall or similar), but it goes away after I use the brakes a few times.
A New Way Of Cheating At Fuel Sheds In Sl !!
Honestly, I pump from the Pelawatta station nearly every weekend, and I have never had that issue. And I mean 1 or 2k worth of fuel, not a full tank obviously. And since you have no clue as to where your fuel indicator should be after pumping anything less than a full tank, I suggest you figure that out first . Also, if your car has the digital mileage meter, I'm sure the two trip meters can be used to compare two different sheds.
- Triumph T R Restore Project
Car Ac Not Cool Enough
I have to top up my car's petrol every 5 days, maybe the fuel tank has a leak! But yeah getting back on topic, it's quite normal for periodic top ups. Plus, your compressor has a pressure switch which prevents the clutch from engaging if the refrigerant pressure is too low (experienced it quite a few times with the old van _it_ had a leaky a/c refrigerant circuit), so there's no real worry about the compressor running sans lube.
Lamborghini Urus
Yeah that makes sense.
Lamborghini Urus
Whats with the tiny door mirrors?
Toyota Sequoia Or Lexus Lx
Neither. Get a VDJ200.
- Post Whoring - Part 2
Battery, 7.2v nimh, the kits come with a normal brushed motor and basic brushed motor controller which is more than enough for casual fun. You can get about 15-20 minutes run time out of one battery pack, and they're not all that expensive either. Keep that as it is, Tamiya kits don't have any interior detail at all. The kit below should make you happy.
