Everything posted by nira74
Honda Ek3 Vtec Lpgas Conversion Experiance
Most of the people I know who had gas conversions done ended up dumping their cars after a while because they just didn't have the patience trying to sort out all the extra complications that arose after some time especially when it came to engine tuning. (Not to mention the one guy whos car went up in flames with the Bootlid ending up on a coconut tree when the gas tank exploded....) For me in today's busy working environment where the amount of time you can afford to spend in garages tinkering with your car is minimal, there is nothing more satisfying than turning your ignition key just once in the morning with your right foot off the gas pedal and to have the engine of my eight year old car start up and settle to a smooth 500 RPM idle without a single splutter or puff. How many owners of Gas converted cars of similar vintage can say the same ?
First Oil Change For A Brand New Car?
Some manufacturers use a special less viscose oil during the running in period of the engine which needs to be flushed out and changed to regular oil after 2000 km or so. Whichever the case it will be clearly spelled out in your owners manual. Safest thing is to follow the instructions in the Manual.
Fuel Economy: 1998 Wingroad
Actually Nissan is one brand you can safely take to the agents for tuneups without any worry. They always sort out the issue. Been running a 2000 Wingroad (Manual) for the last 4+ years now. Colombo Economy averages between 9 and 9.5 easily. Agents tune up with new plugs and injector cleaning done once a year works fine for me. You should also check the fuel filter to see if it's clogged. Y11 Wingroad fuel filter is located in the tank as part of the fuel pump assembly, and I think the Y10 model also has the same type.
Fibre Experts!
He, He,,,,, when u say... 'sells the stuff in KGs'... reminded me of a car i saw at the Garage last week. Some Guy had spent over 300k getting some very fancy bodywork done with new lights and the works and when it was finished, the car was too heavy for the suspension. He then had to modify the suspension to be able to drive the car out of the garage without dragging on the road... finally after some time the Gearbox had busted because it couldn't take the strain of the added weight.......
Insuring Unregistered Car
Any insurance company will issue a temporary cover note pending registration. You have to give them Your Details, the Make and Model of Vehicle, Engine No, and Chassis No.
Special Permits For Tax Payers?
Taxpayers who have paid income tax of Rs.250,000 or more per annum for the last 5 years are entitled to a vehicle permit. However the regulations on the type of vehicle you are entitled to import are not clear.
Nissan Engine Swap
Strangely, there doesn't seem to be a front wheel drive model. The Transversely layed out ones are all from 4WD Cars (Bluebird U12 & U13, Avenir, Pulsar) You may want to look for a SR20VE instead
Nissan Engine Swap
Should be no problem, just make sure you get the right ECU and harness with the engine..
Auto Guru's Help Me, Going To Purchase In This Week
The 17- sprinter-cielo (1500cc) i owned some years back (1987 yom..) did 10+ in colombo, 15+ outstation and could top 140 km/h when I put my foot down. For me that was an almost perfect balance of performance and economy for a first car... bought if for only 375k and sold it 4 years later for 450k..... ah, those were the good old days....
- B4 Tt
- B4 Tt
- B4 Tt
Whats This Car????
Only clue I can pick up from the picture is that the car which was photographed has a set of aftermarket alloys.... not the type that come factory fitted on a Clio V6.......
F Drag Racing !!! I'm Going Corner Carving!!! ... Update On My Car
There is a place called 'Cefiro Motors' ... they are in the same building as Teck motors - the Honda agents... about 2 shops further down in the same block. They have a lot of parts for big nissans. Could try there
Reason For Sudden Performance Decrease
Had a similar problem. Turned out to be clogged injectors. (even after using injector cleaner in the fuel) Simple injector cleanup (manual) + an electronic tune up by the agents corrected the problem... oh and fitted new spark plugs too. One way to check would be to accelarate with the car in neutral. If the car does not rev past 4000 rpm easily there would be an issue
Transfer A Car
The registration book would have the owners name and address. - I guess you could start from there and try and trace him.
Remember Not To Use 95 Octane Petrol + Full Synthetic Engine Oil Same Time
First came across this subject a few months ago when I was contemplating buying a used Audi A4. Looked up a lot of reviews and apparently late 90s Audi & Volkswagen turbo engines are affected by Oil Sludge problems.... Found an interesting article on the subject - the known causes and remedies..... quite interesting reading Second Opinion - Oil Sludge basically what is says is that the main causes of sludge are poor quality oil, poor quality fuel and excessive heat and heavily stressed engines. And interestingly certain engine designs are more likely to have sludge problems than others. Surprising then why someone should come to the conclusion that using the best quality oil and best available fuel should cause the problem....... i think what most of you guys say is true,.... the high price of the oil tends to make the owner keep it in the sump too long which leads to a chemical breakdown of the oil.
Darley Road Advice!!!
My Friend, It's good to go with an idea of the cost of parts before agreeing to those crooks prices. A second hand mirror for a sprinter would have cost about 4000 bucks max. Had a similar 'emergency' about 6 months back when my fan belt broke in the middle of darley road. Got directed to the same joint...... ended up having to teach the 'expert' how to remove the fan belt and nearly squeezed his neck a couple of times when he tried to remove parts which were totally unrelated to a fanbelt replacement ... In general, its best to avoid all the automobile joints on (Both Sides of) Darley road.....
Near Miss !!
I didn't actually see it happen myself, but it cant be so, because the busses and vans he hit were parked further downhill, so it could not have rolled uphill...
Near Miss !!
Was at a hotel in Kandy over the weekend. Saw a frightening site in the morning.... A guy had lost control while reversing out of the car park after a late night function and almost ended up going down a 30ft drop into the tennis courts ! He had also damaged several other vehicles in the process....
Mini As A Family Car
Most of the older ones on sale for higher prices have been re-furbished using parts imported from Japan and Uk (Usually from broken up models.) these are much easier to use as a daily runner run because the parts used are more modern...(disk brakes, dashboard gauges, carburettors, radiators, electric fans and if you're lucky an aircon too.) - such an example would be within your budget. The un-modified ones of the same vintage would be little more difficult to run and you could expect to have to do things like - check the radiator water level daily, replace brake washers once in 6 months and also stall frequently in heavy rain (if your electrical system is not maintained perfectly) - Also if you don't do the majority of your running on carpeted roads, I wouldn't recommend one as a daily runner because the car would literally shake itself to pieces on account of the limited suspension travel and low ground clearance. Basically a mini would need a lot of TLC. For a daily runner I would recommend a used jap car like a starlet or March.
Battery Water !!!!
Guys I just fitted a Amaron 2 months back. It cost me 1000 bucks more than the equivalent Exide normal battery. 1000 bucks extra for a 3 year warranty and without the hassle of having to take it to get the electolyte levels checked every month seems like a bargain to me. It was a bit difficult finding an Amaron though, because the agency has changed hands now. after a lot of searching, I found a dealer in Bamba on Bullers Road between Duplication and Galle Road. Their service was very good too, they didn't have the battery for my car but got it down from the agents and brought it to my office in Colpetty and fitted it for me. They also said that they they have very few issues with these batteries compared with the other brands they deal with.
Aston Martin Db9
Not necessarily,.... from what I've heard if you've got the right connections, you could get a container through without inspection..... if a vehicle came in that way and is not registered or insured, no one would have a clue about it.
Tappet Noise
Is the noise audible from outside the car or do you hear it only when the bonnet is open ? Some people mistake the sound of the injectors firing for a tappet noise. It would be the tappets if you hear it when the bonnet is closed as well.
Fuel Pump Failure?
Experienced a failure in a 301- Peugeot 406 some years back. No symptoms it just cut out and the car had to be towed. It too was an in-tank pump. When it was removed, they found that the pump had simply disintegrated. Agents said it was because the car was run on leaded low octane fuel. (This was when both leaded and unleaded were available)
