Everything posted by nira74
After An Engine Tune Up
Is you car a EFI or Carburettor model ? Usually there is a separate Injector / Jet for cold starts which feeds a fairly rich fuel air mixture to the engine until normal operating temperature is reached. Either way, first check whether there is an increase in fuel consumption to decide whether something needs to be fixed or not.
Cheap Car To Learn Driving... Any Suggestions?
For that budget you'd be looking at Nissan B310s and 12 or 13 Sri Corollas- None of which would be safe enough for someone to learn to drive in.... (Shot gearboxes, no power steering and dodgy brakes) First thing that came to mind are the 14 Sri first generation Starlets - but i think you'd have to increase your budget by about 100k. You could also look for a first or second generation Ford Laser or Mazda 323 Hatchback. their mechanical bits are rock solid. Only need to check for corrosion.
Mini Thermo Stat Valve
Thats a useful piece of info. That means that the extra pressure created by the valve even when open actually helps with circulation. Shall do a little more research on the subject.
Wiper Blades
Bought Bosch from Dimos for one car and liked it so about 2 weeks later bought for the other car as well........ but unfortunately they did not last longer than any of the other cheap brands out there..... about the same quality as all the others. Currently using a set of Korean blades I got from Pioneer in panchikawatta and they are still good after 8 months ! Basically I feel that if you have the time to keep your windscreen and wiper blades clean and free of dirt most blades would work well. On the other hand I would not enjoy it if I paid 1000 bucks ++ per blade and they started squeaking after 3 months....
Faw - Prado Look-a-like
And like most of the Chinese Look-Alike vehicles, the only similarity to the original is the appearance. It's completely different in terms of Components and Engineering and more importantly - SAFETY. Most of them crumple like cardboard on even a minor impact.
Od Button
Final drive is the RPM coming out of the Gearbox. (before the Diff)
Lancer Cedia 2002 Model
If it has a GDI engine, you can expect some costly repairs down the line. Fuel Pump Failure and subsequent Need for Engine Rebuild are very common on these engines because they are designed to run on higher octane fuel than what is available here. You'd be better off looking for a Brand new one which was importd through the agents because it will have a non-GDI engine and they can guarantee any repair work done by them.
When The Fuel Tank Light Comes On
That doesn't sound quite right. Usually the valves need lubrication when running a car that was designed to be used with Leaded Gasoline on Unleaded. Since both the 90 and 95 octane fuels available here are supposed to be 'unleaded' - there would be no difference in terms of the impact on the valves. Actually there are some lead additives available for use on older engines.
Rover Agents?
Ouch,.... poor guy, your friend. The Rover 75 was the last of the Rovers, and finding parts here may be difficult. Anglo Asian - who later became Carplan (Kia Agents) did import a few models in the late 80s.... but they were Austin-Rovers (Montegos, Maestros and Metros.) The models prior to the 75 shared quite a few mechanical bits with Honda Civics and Accords. Though the 75 was supposed to be 'All New', my guess is that you may still find similarities. Best bet would be to source the parts from Singapore or Direct from UK. Could talk to guys who source Mini and other British car parts. But you would have to tell them exactly what you need... Other option is always E-Bay. A buddy sourced a whole bunch of brand new bits for his E46 Beemer through E-Bay and it cost only a fraction of the local dealer price.
Toyota Vios Or Toyota Ist, Pls Advise Me As To What To Buy ?
I think it should be more clearly defined - I think they mean luggage space.. In terms of interior cabin space, I don't think there's any difference. Vios is basically a previous generation Vits with the rear end extended a bit. I think you should also consider the fact that the Vios comes off a production line in Thailand and probably has been modified a bit in singapore with a fancy looking trim, some cheap extra gadgets etc. But the Ist is directly from Japan where build quality would be much better simply for the fact that it's designed and built for a much more competitive market. The Ist is also being marketed rather succesfully in the US under a different brandname.
Mighty Mini Club Charity Drive
Black 'Mini 30' - the 3 Sri one. Both me and my bro were there. He runs and maintains it now cos I don't have much time to spend on it.... We had to leave a bit early on account of the kid getting restless. Sorry I missed you. Which one did u drive ?
Here are a few more.....
Tel # Of Mr Paint
They've got quite an impressive workshop, but I've been there only twice with two friends and they botched both jobs when it came to colour matching. When the difference was pointed out they re-painted FOC.
Motorshow This Weekend
Personally I don't think that new look suits the MX3/Eunos/Autozam. The original shape is very sleek and neat. The new bonnet, buffers and lights make it look like someone heavy sat on the bonnet and caused everything to 'spread' a little .......
To All You Diesel Vehicle Owners Out There.....
No worries my friend, I remember some time ago there used to be lots of fuel additives and such products advertised which were supposed to reduce the smoke of diesel engines. Nowadays they're not even heard of. Were these a failure ? Or have we just resigned ourselves to the fact that diesels smoke, and we can do nothing about it ?
Some time back while I was in a heavily crowded church the whole place started to fill with Diesel fumes. When I looked outside, saw that a young guy in a fairly worn out looking diesel vehicle who had come to pick up someone had parked under the porch because it was raining, and was chatting on a mobile phone with the engine and A/C running. He seemed pretty oblivious to that fact that he was suffocating about 400 people until I went over to his car and told him so. I had forgotten about the incident till I read the article below on BBC..... Diesel pollution 'clogs arteries' "Diesel fumes contain damaging particles Diesel fumes appear to combine with artery-clogging fats to raise the risk of heart disease, research suggests. Scientists found the two act in concert to switch on genes that cause potentially dangerous inflammation of the blood vessels.........................." I'm not saying that petrol fumes are any less harmful (infact they are more damaging to the environment) but was just wandering how many owners of Diesel vehicles out there (including luxury ones) are actually concious of the fact that their vehicles are generally noisier and the smoke they emit is rather unpleasant in situations like the ones above and also how many actually maintain their vehicle in such a way that the smoke is minimized.........
Yaris Or Sunny Super Saloon
This is the second time I've heard someone say that. Actually the Nissans have a fairly modern rear suspension setup - the multilink beam which is quite a few european front wheel drive cars. Exerpt Below from Autoweb: Torsion beam suspension Most modern mini cars up to C-segment (for instance, VW Golf) employ torsion beam as the rear suspension. Why? compare with double wishbones, multi-link and trailing arm suspensions, it engages little width of the car, thus enable greater rear seat room. It is cheaper too. Compare with MacPherson strut, its shock absorber is shorter and can be inclined steeply away from the vertical, thus engage less boot space. In fact, torsion beam suspension is only half-independent - there is a torsion beam connecting both wheels together, which allows limited degree of freedom when forced. For some less demanding compact cars, this save the anti-roll bars. On the contrary, it doesn't provide the same level of ride and handling as double wishbones or multi-link suspensions, although in reality it is superior to its only direct competitor, MacPherson strut. Most of the Europe's best handling GTIs employed this suspenion.
Question Regarding Some Vehicle Ads Al
Most army vehicles puchased since the late 80s were registered with the RMV as well. Each car had both a 'Civillian Number Plate' and the usual Army plates. This was done due to the security situation at the time, and the civillian plates were used for day to day running and the army plates for official functions etc.
Only way is to get the upper and lower tanks de-welded and cleaned by some place like radiator house (darley road). but if as you say everything is now in order and the temp gauge is below half, then there's no need to take such drastic action. Too much 'cleaning' (chemical or otherwise) could just as well expose some weak areas in the radiator piping and increase the chances of failure. As the old saying goes - if it aint broke don't fix it... Everything should be fine provided the car is run regularly for a decent amount of time. That applies not only to the radiator but most other mechanical parts of the car.
Nanotech Cover - Is It Works ?
Perhaps the guys who fitted the gadget may have accidently disconnected the wiring to a sensor or something. If this happens, the ECU would automatically make the engine run a rich fuel mixture to compensate for what it sees as a fault in the EFI. This happened to me a while back with a Toyota Sprinter Cielo. In that instance the wiring had been deliberately fiddled by the previous owner to make it run rich when racing. Car was doing 6-7 km/l. Fault was identified after electronic diagnostics & tune up. It did 10+ km/l without any problem thereafter.
Starting The Blower Whe The Car Is Parked
Basically the Blower works only with the switch in the On Position because that is the usual position the switch would be in when the engine is running. The blower is basically an electric fan and that would tend to drain your battery if you run it with the engine switched off. I own a Wingroad Y11 which is basically the wagon of the FB15 and strangely the blower does work with the key in the ACC position. This is of no use anyway, cause without the engine and aircon running, all you get is hot air out of the blower...
Even if you do replace the thermostat, it will very likely get clogged and give trouble again soon unless your engine block is very clean, cooling system perfect and you run on a high grade coolant. But knowing Mini's it's likely it will require regular topping up thereby leading to contamination of the coolant... Most cars on the roads in Sri Lanka these days run without the Thermostat without any side-effects.
Carina Or Vios?
Heard from a reliable source that most Vios cars develop a front suspension noise after a few months running on our roads. Apparently even the agents are unable to rectify the problem. A friend of mine sold his Vios because of the same problem.
Traffic Police
- Honda Hr-v Price Point
My brother had a 2wd non-VTEC Manual one a while back. Performance is very good, it has a screamer of an engine which loves to be revved. Fuel Economy was excellent 12 km/l in colombo and 14-16 outstation. If buying second hand, a manual would be the one to look for because the Auto boxes are known to give trouble if not properly serviced regularly. My guess is that a registered one would cost around 2.4 upto 2.8 million. - Honda Hr-v Price Point
